changing wheels input please
dmaxfield
After all the chat over my wheels,I have now decided that they must go.But i am down to the same problem is getting clearence on the brembo's.So i am open to suggestions what to put on and best place to go.
orangecurry
Original 16s.
Go to BMW or Hartge. No-one else.
there - I've said it.
Rosc0PColtrane
Go large!!!
get some proper rims RD's/alpinas other bmw wheels, split rims?
tim-ix
Don't go much bigger than 16"s. What's the point of lavishing so much attention, not to mention time and money, on a car renowned for it's handling characteristics then making it undrivable by loading it up with unsprung mass and spoiling the suspension geometry?
I like the original 16s on C76JON's M3, but I don't know how big your brake discs are.
Rosc0PColtrane
what, like they did on the m3 touring cars you mean?
tim-ix
Fair enough, but you wouldn't want to drive a touring car day-in day-out would you? A quarter inch of suspension travel and no ground clearance isn't my idea of fun after a day in work. If I had an M3 I'd like to be able to fully exploit that chassis on the potholed tarmac that passes for the UK road network. I'm sure that some compliance in the sidewalls would make for a more enjoyable car I'd be more inclined to use.
how very true, big wheels and big drop = shocking ride!
jon's car has 17's
jon's car has 17's
tim-ix
Are Jon's 17's? They look just right. His car looks like you could eat your dinner off the tyre treads.
Rosc0PColtrane
Fair play about the road conditions. My comment was more a reference to larger wheels ruining ride full stop. I'm sure in most cases it' sprobably true but if so, why would touring cars use larger diameter wheels if it had a negative impact on handling? I'm sure there's more contributing factors than just wheel size to affect a cars handling attributes and therefore the decision on wheel size.tim-ix wrote:Fair enough, but you wouldn't want to drive a touring car day-in day-out would you? A quarter inch of suspension travel and no ground clearance isn't my idea of fun after a day in work. If I had an M3 I'd like to be able to fully exploit that chassis on the potholed tarmac that passes for the UK road network. I'm sure that some compliance in the sidewalls would make for a more enjoyable car I'd be more inclined to use.
As far as potholes go, especially this time of year they do seem to be more prevalent but to say that the road network is potholed to that extent is sensationalism. Not every road is potholed to the extent they are undriveable on larger diameter wheels? If so, why do modern manufacturers offer cars with such large diameter wheels as standard?
Surely that level of chassis exploitation should be kept on the track? Driving a car on it's limit leaves little or no margin for error should emergency action be required to evade an accident. In which case, the preferential track conditions would be fine for larger wheels?
I can't say that running larger wheels on my cab hasn't lead to the occasional crashy moment but on the whole, the ride is good and never left me in physical discomfort.
I just feel it's too easy to towthe common way of thinking on here just because it fits with popular consensus.
Then again, I could be completely wrong!!!
Turbo-Brown
- Boost Junkie
Needn't be heavy if you spend enough!
Each one of the rear wheels for the GT6 which are 9.5x17 with 245x35R17 tyres weighs LESS than a standard 205 GTi 15" Speedline wheel with tyre (the Speedlines were the lightest standard wheels apparently)
Mate of mine works on some rich guy's race car and brought in a mag splitty which was absolutely massive and weighed absolutely f**k all! You could literally pick it up with one hand and shake it about like a tennis racket (can't think of a better analogy)
As I understand it though, you need to have mag wheels checked every so often for fatigue cracking and they're only good for scrap if they've started to go
maxfield
16s wont fit 17or over
BBS LMs i've told you before
oh and BTW thanks for the card but you have ruined my xmas
maxfield
its not all that bad imoSimon13 wrote:how very true, big wheels and big drop = shocking ride!
my dad drove 1k+miles and didn't complain after
and he's old and fragile
maxfield
BBS CH
BBS RC
BBS LM
BBS RC
BBS LM
tim-ix
I love the RCs. Proper
The roads in Swansea really are abysmal. Maybe they're better where you are, but I wouldn't fancy driving any car on 30 profiles, like a 911 Turbo for example. Maybe Swansea roads really are worse than elsewhere, the weather is.
Very light alloys are probably a magnesium alloy, rather than the primarily aluminium alloy used for most road car wheels. Mg isn't great for road wheels because it doesn't stand up to stress or road salt as well as ali. Not such a problem for a race car.
Car mags are forever moaning about newer cars being offered with such low-profile tyres that the ride is affected. They normally seem to apply this criticism to BMW, Audi and Merc, regularly advising buyers to stick to a smaller wheel and higher tyre profile rather than opting for the "marketing dept spec" 18" or 19" rim. I remember this in relation to the E46 M3. BMW's habit of fitting stiff sidewalled run-flats doesn't help either. If we were Germans with German roads it'd be different, but we're not.
If you're on your own and pressing on you probably won't even notice the ride quality but it's excruciating once you've got passengers in the car or if you're just not in the mood to thrash it.
Rosc0PColtrane
maxfield, I like these 18's...
Rosc0PColtrane
I should imagine 30 profiles are like driving on rubber bands!! Am running 40 profiles which probably helps!!tim-ix wrote:I love the RCs. Proper
I have also read the reviews where journos moan about tyre profile. Possibly hankering for their old austin maxi with bench seats, leaf spring suspension and 80 profile tyres!!!! I guess it all boils down to personal preference and what you are used to!!!
I still think excruciating is a bit harsh. I rarely push mine and stick to speed limits around town. TBH occasionally excessive lumps bumps and troughs make me curse but nothing has caused physical discomfort.
dmaxfield
can not go no lless than 18s because of the size of discsorangecurry wrote:Original 16s.
dmaxfield
bit to late with all the money spent on different suspension,besides I only did the car to look at Loltim-ix wrote:Don't go much bigger than 16"s. What's the point of lavishing so much attention, not to mention time and money, on a car renowned for it's handling characteristics then making it undrivable by loading it up with unsprung mass and spoiling the suspension geometry?
dmaxfield
bought them the first time will not go onblatantarrogance wrote:maxfield, I like these 18's...
m3ben05
dmaxfield
hi benm3ben05 wrote:Hows it going dale mate?
Glad you have decided to change the rims but im really not sure what will fit and look good!
Anything like style 5's, rondells etc are out of the question without doing other mods to the car, if you wanted to use these wheels you would need new arches (like im planning)
fopund some bbs split rims but they are about £570 each the back will have a deeper dish than the front.
hows the motor going and i dont suppose you fanct the nurburgring next march
m3ben05
Ouch, thats pricy!
Deeper dish at the back always looks better IMO, which BBS are they?
Mines going ok i think, iv not seen or driven it for like 2 months! Its in storage in sussex
I wish i could make the ring in march but il be right in the middle of my final uni project by then. If your going again any time after april il definately be up for it!
dmaxfield
My 850 as got mk motorsports on and you wanna see the size of the dish on them looks fabm3ben05 wrote:Ouch, thats pricy!
if you can make the ring towards the end of april thats ok as i havenot booked anything yet
m3ben05
dmaxfield
thats you christmas box out the window old and fragilemaxfield wrote:its not all that bad imoSimon13 wrote:how very true, big wheels and big drop = shocking ride!
dmaxfield
I din t realise the ones i been looking at are bbs Lms like my son as been telling me to getm3ben05 wrote:Ouch, thats pricy!
Taylor325i
- Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
maxfield wrote:
BBS LM
These wheels get my vote!
Taylor.
dmaxfield
it was 1557 miles iand i did not stop for nop moor than 15 mins at a time although the mountains gave me a saw neck ,but hey was worth itdmaxfield wrote:thats you christmas box out the window old and fragilemaxfield wrote:its not all that bad imoSimon13 wrote:how very true, big wheels and big drop = shocking ride!
orangecurry
touring/race cars run on a race track - the difference between a track and a road surface is huge. Roads are deliberately bumpy/undulations/holes in the tarmac to assist with water run-off and to decrease aqua-planing, and to increase braking effect in the wet - therefore too small a profile and too hard a ride means poor handling and understeer, and at the other end of the scale, no warning of imminent loss of grip at the rear.blatantarrogance wrote:Fair play about the road conditions. My comment was more a reference to larger wheels ruining ride full stop. I'm sure in most cases it' sprobably true but if so, why would touring cars use larger diameter wheels if it had a negative impact on handling? I'm sure there's more contributing factors than just wheel size to affect a cars handling attributes and therefore the decision on wheel size.tim-ix wrote:Fair enough, but you wouldn't want to drive a touring car day-in day-out would you? A quarter inch of suspension travel and no ground clearance isn't my idea of fun after a day in work. If I had an M3 I'd like to be able to fully exploit that chassis on the potholed tarmac that passes for the UK road network. I'm sure that some compliance in the sidewalls would make for a more enjoyable car I'd be more inclined to use.
Then again, I could be completely wrong!!!![]()
A super smooth race-track means you can run very hard suspension (to minimise body roll) lowered with less suspension travel (lower centre of gravity) and minimum tyre profile - you still have little warning of loss of grip, but you shouldn't be on a race track if you don't have some slight skill, but at least as the surface is so smooth the breakaway is very progressive rather than sudden (e.g. as the car goes light as you go over a bump on an ordinary road)
orangecurry
superbly puttim-ix wrote:Don't go much bigger than 16"s. What's the point of lavishing so much attention, not to mention time and money, on a car renowned for it's handling characteristics then making it undrivable by loading it up with unsprung mass and spoiling the suspension geometry?
orangecurry
lose the Brembos - go back to 16s - the car will show it's ability. You've spent how much on the car?dmaxfield wrote:can not go no lless than 18s because of the size of discsorangecurry wrote:Original 16s.
Keep the brembos in a box in the garage so you can put them back-on if it turns out I am wrong. You'll ALWAYS be able to sell on any 16s you buy, if you end up not liking them
dmaxfield
No thanks love it the way it isorangecurry wrote:lose the Brembos - go back to 16s - the car will show it's ability. You've spent how much on the car?dmaxfield wrote:can not go no lless than 18s because of the size of discsorangecurry wrote:Original 16s.
orangecurry
here is what hartges would look like... in 17s
http://cgi.ebay.co.uk/HARTGE-17-ALLOYS- ... dZViewItem
maxfield
17s will fit
and brembos will stay
BBS lms get my vote
and what is my xmas box
and where did you get the card from bacause it wern't anywhere in spain
BBS lms get my vote
