What is the..................
YODI
Post Thu Nov 30, 2006 10:40 pm
In your opinions,
what is the most common engine transplant into an E30??
YOdi
billgatese30
Post Thu Nov 30, 2006 10:42 pm
most popular convetrsion is probably the 2.7, although that is a conversion of the original engine, not a transplant
most popular transplants are probably m50 transplants, or putting m20's into m10/m40 cars
YODI
Post Thu Nov 30, 2006 10:43 pm
OMG codes PMSL..... What are teh codes converted?? :D:D
billgatese30
Post Thu Nov 30, 2006 10:49 pm
m20 is the 2.0ltr or 2.5 ltr engine found in e30 320/325's this si also the block that is used for the 2.7 conversions
m10 and m40 are the 1.6 and 1.8 litre engines out of 316/318 cars and are often replaced with 2.5 or 2.7 engines (which are based around the same block - m20)
m50 engines are the 2.5/2.8 litre engines found in e36's
oh, and then theres also the m30 block - which was the 3.5 litre engine found in most 535i cars of similar age to the e30
YODI
Post Thu Nov 30, 2006 10:51 pm
Ah ok so I have an M50 :D
Good to know LOL
tee
Post Thu Nov 30, 2006 11:01 pm
If that is your s plate in the pic that will be the later M52.... basically an m50 with VANOS
