I bought it.... 318i Lux Cab !
lukescott
Post Sat Nov 18, 2006 11:26 am
I bought it....... :D :D :D 1993... 318i Lux Cab...24,000 YES 24,000 fully documented miles. OK it was dearer than you guys would pay but it's worth its weight in gold here in Dublin. 295 miles non stop from Fleet in Hampshire to Holyhead Wales last night and she never missed a beat :D :D :D Every single piece of paper came with it. The bmw sales invoice for £18,500 8O 8O sterling for the car to include all the extras she had fitted. Just one question please guys..... I have not had time to read the owners manual fully yet but I saw a section on the heater and it mentioned "automatic mode" or similar. Is there a thermostat on the fan (blower) on the heat ?.
lukescott
Post Sat Nov 18, 2006 1:09 pm
Talking to myself here but I have read the owners book and still cant figure out the heating.
On the control panel with the three sliders... to the right of the sliders is a round button with an led. When you press the button the led flashes once. It says in the manual its for reciculation of the air in the car. ANy help here please. The heater worked great last night but today I pressed this button and now I cant get the blower to work.
mrLEE30
Post Sat Nov 18, 2006 1:42 pm
firstly congratulations on your new purchase!
secondly i dont know of any E30 with automatic fan control (although i may be proven wrong) there is a thermostat that i know controls the airconditioning and is used to switch on and off the compressor, but as i said i have not heard of a full auto system. when you say a button with an LED do you mean a botton with a light inside that turns orange when you press it? or do you mean a button with a LED, as again to my knowledge no buttons on the E30 had LED's. if it is the orange button that is the recurculate button and it closes the flap that allows air fron the outside of the car to blow through your heater matrix, instead it takes the air from the passenger footwell, good if its real wet outside and damp. with that button on the fan on my car automatically comes on the lowest setting (but that may be as i have AC)
lukescott
Post Sat Nov 18, 2006 2:17 pm
mrLEE30 wrote: when you say a button with an LED do you mean a botton with a light inside that turns orange when you press it?
Thats it. It appears to be the recirculation button alright. Its funny because if the engine is cold the heater fan wont blow hot air till the heater gauge shows around half way up... or 5 minutes of driving approx.
mrLEE30
Post Sat Nov 18, 2006 3:10 pm
does the fan work normally without this button pressed?
Some E30's had switches that controlled how the fan would work depending on where the sliders are set, try switching to demist the fan should work then.
do you mean the fan does not work or the air is not hot? the hot air basically comes from the engine cooling water, so if the engine is cold there will be no hot air, when the engine is hot so is the water in the cooling system so your fan will blow hot air!!
Nelly
Gumbo
Gumbo
Post Sat Nov 18, 2006 3:21 pm
Sounds like your Cab must have air con on it then?(a rare item) probably got a slatted trim piece in front of the ashtray?? - - - That orange button sounds like the re-circulating cabin air button if i'm correct, should be located above a Blue button with the aircon snow flake on - to the right of the heat selection dial??
"I F**KING LOVE YOU GUMBO"
Nelly
Gumbo
Gumbo
Post Sat Nov 18, 2006 3:24 pm
That button also shuts off all out side passage ways into the cabin via the heating system vents - i think you shouls hear a slight machanical noise when you press it.
Neil.
mrLEE30
Post Sat Nov 18, 2006 3:35 pm
just a thought.. you said the button flashed once, thats not right, the button should stay lit to indicate the the air is recirculating (with the noise as mentioned by nelly) or off to indicate the air is from the outside. if the light is noe not coming on and your fan is not working then i suspect the button is faulty as there is a link from that button to the fan, but it is normally on cars with A/C (indicated as nelly says by a blue button next to the yellow button) to stop the system freezing over if the AC compressor is on and the fan is not.
tell us this
1. does the fan now work on all four speeds with the orange light off?
2. does it work with the ornage light on?
3. does the orange light stay on when the button is pressed or only when you have your finger pushing it in?
note: i cannot remember if the button lights dimly when the headlights are on i dont think it does but i am not sure, do the above test with headlighhts off.
mrLEE30
Post Sat Nov 18, 2006 3:38 pm
my cab has AC but no slatted piece near the ashtray, the evaporator is behind the dashboard, which bit do you mean nelly??
lukescott
Post Sat Nov 18, 2006 5:06 pm
mrLEE30 wrote: tell us this
OK. I just checked the car from cold. The fan worked straight away, so I wonder if there is an intermitant fault somewhere. The little led on the recirc button does not stay on. When you press the button the led flashes for a second only so I cant figure out if its fresh air or recirculated air :?
Gortour
Post Sat Nov 18, 2006 6:33 pm
Does the recirculating button - if that's what it is - latch in when pushed, or does it self release? If self release, the button may be broken. Recirculation should be a push on, push off switch.
And does it have the button above with the blue light in too?
lukescott
Post Sat Nov 18, 2006 7:31 pm
gortour wrote:Does the recirculating button - if that's what it is - latch in when pushed, or does it self release? If self release, the button may be broken. Recirculation should be a push on, push off switch.
No it wont "latch in" ! So I assume the switch needs replacing. And no there is no air con on the car.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sat Nov 18, 2006 7:33 pm
congrats on getting the cab mate just need to get some pic's up now fella,
after all
:ttiwwp:
Gortour
Post Sat Nov 18, 2006 7:37 pm
lukescott wrote:No it wont "latch in" ! So I assume the switch needs replacing. And no there is no air con on the car.
First stop has to be a new switch then. I haven't seen one on an E30 like that, they're usually only paired with the aircon switch. You may get one from a 6 or 7 series, E23 shape. Good luck
Gouki
Post Sat Nov 18, 2006 11:14 pm
looks like temptation was there, good luck with it mate, sounds like a good car.
mrLEE30
Post Sun Nov 19, 2006 5:55 am
yep second that, get to the stealers they will not be stupidly expensive. report once you have changes if any more probs, otherwise it will be the fan blower resistor
lets have some piccies then m son!!
