Which rear sub-frame bush's?
oguz327
Captain Armco
Captain Armco
Post Thu Nov 09, 2006 7:42 pm
One of my rear sub frame bush's is one the way out or long gone!
Are there any alternatives other than the standard ones and polly bush's?
Id like quite a hard wearing bush that is suitable for both road and track use, what are you folks using and what do you recomend,
Oz
Post Thu Nov 09, 2006 9:38 pm
standard bushes!
eko
Old timer
Post Thu Nov 09, 2006 9:39 pm
From the dealer,not GSF :)
stuartgallafant
Post Thu Nov 09, 2006 10:04 pm
oguz, i can supply these for under Ԛ£40
i can fit for a good price too?!! :winkeye:
jonb
Post Thu Nov 09, 2006 10:24 pm
oz
thats a kind offer from stu.
ive no doubt demlot has offered change them. but it needs to be in the hands of someone who knows what there doing. :)
Post Thu Nov 09, 2006 10:31 pm
:teehee:
Nelly
Gumbo
Gumbo
Post Fri Nov 10, 2006 12:32 am
There not that bad to change (giggle giggle) hardest thing is having the old ones pressed out + the new ones pressed in.
P.S. stick with the standard bushes Oz.
"I F**KING LOVE YOU GUMBO"
oldroydsr4
Post Fri Nov 10, 2006 12:55 am
I use the powerflex bushes, it was a mission to get the old bushes out. Had to use a welder in the end winkeye
Powerfles bushes SHOULD go in easier, however IMHO i think the quality has dropped off slighly. Fitted 3 sets on different cars in the last few years and it gets harder every time , with fit etc.
The results are good though
stuartgallafant
Post Fri Nov 10, 2006 10:25 am
jonb wrote:oz
i dont get this! is this a crack at me or demlot?
dark_sounds
Post Fri Nov 10, 2006 10:35 am
take it as a complement mate ;)
are poly bushs that much more harder wearing cos all my underside will be needing a recon and need ultra hard wearing stuff, cos with 350-400 kgs in the boot,, it needs it lol
Directed CompX's 12"... 2off. 1000 watts RMS, dual 2ohm VC. 90£ each!!
8600 Luna Phone 480 POSTED BNIB
stuartgallafant
Post Fri Nov 10, 2006 10:39 am
they are harder wearing, but its more focused on the material they use being stiffer.
with poly, you dont get anywhere near as much flex as rubber, so nothing moves around, which is why they use it in racing applications
however, you do lose your comfort aspect too
Andyboy
Alpina Colada
Post Fri Nov 10, 2006 10:44 am
You haven't lived until you've changed Compact rear beam bushes. What an utter c*nt of a job. E30's have a bolt that drops down and can be punched back up. Compacts have a stud that screws into the shell. That means exhaust off, flexy pipes disconnected, propshaft off the diff and drop the whole back axle down enough to unscrew the studs. Bastard.
stuartgallafant
Post Fri Nov 10, 2006 10:45 am
yeah, compacts are great!!!
thats a 4 hour job at my place!!
jaistanley
Post Fri Nov 10, 2006 4:56 pm
I pressed my old ones out using a bottle jack and a student accomodation doorway. Bloody landlord was a nob anyway.
Fitted poly bushes and found it greatly improved the feel of the car but to the detriment of noise (as you may expect). The car doesn't feel crashy of bashy now, but higher frquency road noise is transmitted to the chassis much more.
If you aren't a hard and fast boy racer such as myself or fitting a 300 brake engine (just like me, not fitting at the moment that is) go for the rubber ones. Driving my very clean 325i, which has std everything, and you can really feel and hear the difference.
Good luck.
Jai
Demlotcrew
Post Fri Nov 10, 2006 5:52 pm
jonb wrote:oz
Jon did you ever go to school?
I dont offer to do any work on anyones cars, people ask me.
:eek:
oguz327
Captain Armco
Captain Armco
Post Fri Nov 10, 2006 6:54 pm
Originals it is then, main dealer of coarse :D
Andy335Touring
Post Fri Nov 10, 2006 7:58 pm
I didn't want the extra noise so i had gen BMW bushes fitted, only problem is they are a little weak when you launch the car hard as you get wheel hop/axle tramp(or what ever you call it).
I wish there was a bush that was harder than standard but doesn't comprimise by causing too much noise.
M5pilot
Post Fri Nov 10, 2006 9:40 pm
The Powerflex bushes make a considerable difference over the standard ones.
The biggest problem with them is that the do increase the road noise a little but the ride doesn't get crashy.
I fitted them to my Touring and the results were very positive.
If it's a track car then Powerflex over standard. You can even get the much harder ones from powerflex in the black compound but noise and vibration levels will go through the roof.
Sal
dark_sounds
Post Fri Nov 10, 2006 10:52 pm
sound deadening will help, lay a bit on the underside of the rear bench and this will reduce the noise a bit though obviously addictional cost.
i have almost muted my exhaust note! until you open the window!
johnono
Post Sat Nov 11, 2006 12:09 am
Andyboy wrote:You haven't lived until you've changed Compact rear beam bushes. What an utter c*nt of a job. E30's have a bolt that drops down and can be punched back up. Compacts have a stud that screws into the shell. That means exhaust off, flexy pipes disconnected, propshaft off the diff and drop the whole back axle down enough to unscrew the studs. Bastard.
bollax :lol:
we had both sides done in half an hour, usind an air drill with a puller attatchment
was a peice of piss fella
one side at a time.
Andyboy
Alpina Colada
Post Sat Nov 11, 2006 12:41 pm
Yes of course you did mate, of course you did. I believe you, honest. But it's the same with any car and any job - there is always someone who can do a 2 hour job in 30 minutes flat. :mad:
e30bmlover
Ac Schnitzer prophet
Post Sat Nov 11, 2006 1:20 pm
standard ones geezer.
