Cab Windows
chu346
My windows on my convertible don't sit correct. Is there a way of adjusting them? I'm getting abit worried about breaking one of them. The front windows don't seem to fit the rears and they catch on the roof when i shut the doors.
DemonDaz
I am not very good at explaining things like this, but I have adjusted the front windows on mine...
there are two adjustments, to change the parallel fit. Lower the window half way, and loosen the two screws towards the front of the diagonal beam. Press the window against the guide on the front quarterlite (spelling?
) and shut the window, now tighten the screws again.
To Fit the window against the top seal, there is a screw on the regulator frame, lower the window slightly and turn the screw, now check the window against the top seal.
How I wish I'd have taken photos!
chu346
Well, i had ago but i just don't have a clue which screws/bolts you mean? Don't suppose you could do me a diagram.
DemonDaz
I'll try to get round to it this week!!
TBH, The Bentley manual is essential material!
chu346
I mangaed to get a pic. Hope this is of some use.
DemonDaz
Didn't help that I had front and back the wrong way round!!!!
A = Parallel Fit
B = Fit against top seal.
JAMZ
very handy:
Driver side window cacthing roof,hitting top of quater ever so slightly..with this is mind:
MAke sure the window is square with quater glass then tighten A screws..
once its all square there go for the B screw to adjust the amount the window travels up..
The thing im worried about here is once ive adjusted it to miss my roof it wont have a very solid water-seal.
ONCE it stops raining il take a look
nav786
im gonna giv this a go tommorow
FOR SALE
SONY PSP'S £100
