want to achieve a flat look
Estoril-5
Post Thu Nov 02, 2006 10:08 am
i want to desperately lower my cab.
but i dont want it higher or lower at one end than the other.
i want an even drop all round, so its sits square/flat however u describe it.
do i go for 60mm drop or 40mm drop??
and whick kit do i go for?
any pics guys
thanks
p.s. il be running 15's or 16's max.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Nov 02, 2006 11:42 am
Im gonna drop my cab all round 35mm and run it on 17's, Im not goign to chnage the shocks. Fingers crossed it will be ok
If ur after a kit try Sal the zone shop
Ziggy
Post Thu Nov 02, 2006 12:07 pm
I like how my cab sits (surprisingly): http://www.e30zone.net/modules.php?name ... ic&t=37665
I kinda cheated though - FK adjustables on the back, so I can put it where I want it! :)
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Nov 02, 2006 12:31 pm
Ziggy did u jsut change the back shocks or all round??
What sort of price did u pay for the shocks??
Also slightly off topic need to talk to u about the map mirror mod winkeye
dazleeds
old skool raver
old skool raver
Post Thu Nov 02, 2006 12:33 pm
cliffybabe wrote:Ziggy did u jsut change the back shocks or all round??
map mirror mod??
seem to remember something but cnt recall? :?
www.oldskoolfantasy.co.uk
jmc330i
Post Thu Nov 02, 2006 12:41 pm
I guess the only way to get the exact 'flat' look would be to use coilovers, as Ziggy said, that way you can choose the ride height you want.
dazleeds wrote: map mirror mod??
Probably wiring the map lights to come on when the doors open.
James
'91 325i Sport
'93 318i touring 16v
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Nov 02, 2006 1:54 pm
Na as in fitting the map light mirror in a cab winkeye
Estoril-5
Post Thu Nov 02, 2006 3:53 pm
do i need springs or shocks and springs.
i dont want to go the coilover route
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Nov 02, 2006 3:59 pm
Sorry to hijack the thread with my map light question my bad :roll:
Im gonn atry spring on my cab first off and go from there winkeye
Rosc0PColtrane
Post Thu Nov 02, 2006 4:01 pm
I lowered mine 35mm all round on springs with standard shocks. It's virtually flat, shows some bias towards the front
Hyperion
Post Thu Nov 02, 2006 4:12 pm
i have a 40 mm drop all around and i think it looks quite "flat".
Estoril-5
Post Thu Nov 02, 2006 8:31 pm
want mine a bit lower than yours hyperion,
esp as i want to run 15's or 16's.
what you guys think 60mm all round?
SilverShadow
Hartge Crew
Post Thu Nov 02, 2006 9:05 pm
Estoril
I have been down this route with my cab!
I was running a set of 60mm springs on it first but the arse of the car was too low. After this the shocks were shagged so i changed them, to some bilstien ones and run 60/40mm springs, looked flat for a few months then I dnt know if it was me but started seeing the arse dropping again.
After this i invested in a coilover kit and now its runnning nice and flat. you can adjust to your own preference.
I always raise it slightly from the rear when i put my hardtop on b4 the winter kicks in and then slam it during the summer! winkeye
Cotty
Hartge Crew
Post Thu Nov 02, 2006 9:15 pm
Estoril-5 wrote: want mine a bit lower than yours hyperion,
Yep 60mm all round. Wish I had done the same, this is 60/40mm on 15" wheels
before
after
Cotty
Hartge Crew
Post Thu Nov 02, 2006 9:18 pm
People keep saying the back will settle but I cant see it. Looks like a hot rod with a nose down stance. I dont like it as it is.
How much is a couple of bags of cement :twisted:
fuzzy
He who sleeps with "Gingers"
Post Thu Nov 02, 2006 9:44 pm
i had a 40/40 drop on my touring but was unhappy with the front end still sitting up so changed it for a 60/40 drop which is much more even,but then my engine weight will be different to yours.
Estoril-5
Post Thu Nov 02, 2006 9:50 pm
mines a 320i and its a cab,
so should i go for a 60mm fr and 40mm rr
or go 60mm fr&rr??
hammoj28
Post Thu Nov 02, 2006 9:54 pm
I sometimes think that 60/60 looks great tbh.
24v tech2
GDBN
Post Thu Nov 02, 2006 10:29 pm
This is my cab on the H&R cup kit ... def a bit lower at the front.
G
Hyperion
Post Fri Nov 03, 2006 6:02 am
You also need to remember the a rear drop with 60mm will eat your tyres up. it those look cool, but you will be changing tyres sooner. The rear suspension on the e30 is not very adjustable when it comes to camber.
Ziggy
Post Fri Nov 03, 2006 9:38 am
I've got sport shocks on the back, & m3 on the front - works for me :)
My fronts are quite low too - 60mm IIRC.
cliffybabe wrote: Also slightly off topic need to talk to u about the map mirror mod winkeye
What dya wanna know?
When I get round to it, I'm gonna re-wire mine. It currently comes on with the main interior light, but that means I can't have just the map light on. Could obviously have em independantly switched, but I want em to come on with the doors too!
Estoril-5
Post Mon Nov 06, 2006 3:20 pm
any pics of a cab on a 60mm allround drop?
and which kit do you guys recomend?
cheers
J_Mac
Post Mon Nov 06, 2006 7:03 pm
I have 60/40 front/back and running on 17's
don't know if it's a common problem but going around a corner, quite slow, near full lock hit a small bump which obviously made the car bounce slightly and the o/s wheel caught the lip of the wing and bent it out a small bit, not much but doing that a few times is not going to be good for the wheels or wing
also smashed my sump to pieces on a slip road to the a2 due to a lump of tarmac in the road
the risk of running it at 60mm and just my bad luck
really not trying to put you off, running low looks the nuts, imo i like the nose down look but flat is cool to tho, whatever you choose will look :cool: you decide it's your car mate
Estoril-5
Post Mon Nov 06, 2006 11:50 pm
you got any mopre pics dude?
jon_pure_british
Post Tue Nov 07, 2006 12:02 am
who had their e30 on a 90 drop with toplines?
iirc it was black or dark in colour
that looked sweet as
Clacton-On-Sea
Essex
J_Mac
Post Tue Nov 07, 2006 9:21 pm
rears only got steels on atm alloys worn :-x
