I'm sure this has been asked before but I can't uncover it any searches...
What is correct offset for an E30 M3?
Will an ET13 9" wheel fit with no arch rubbing probs.
M3 Offset...
jpboost
I'm pretty sure that won't fit at the front. You might just be ok at the back, depending on tyres and how low it is.
8x17 ET13 'just' fits on the front. 9x17 ET20 fits fine at the back. but it really does all depend on how low it is. I had mine rubbing on the std 15's (ET30) at one point, but it was running 15mm spacers all round (which would make the equivalent to ET15) it was very very low though.
f13ldy
Oh yeah forgot to say that the fronts would be 8".
So the fronts would be fine but I'd be needing a slightly higher offset on the rears. Is there anything you can do to eaise the offset of an Et13 wheel?
The car isn't lowered at the moment, but I'm looking to get some coilovers so I've no arch gaps at all, probably best I get the wheels on first.
jpboost
the only way to raise the offset is to machine metal off the inside of the wheel (where the wheel meets the hub). Depending on the wheel, you may be able to take a few mm off, but I doubt you'll get them to much better than et15. But offer them up and see what they look like.
I suppose it all depends on how much you like the wheels, and how cheap they are. most things can be 'made to fit' it just depends on how much work you;re prepared to do. 9*17 Et13 isn't miles off, you'll need to roll your arches without doubt. it might fit... there are people running 10" rear wheels, but if all comes down to tyre size and ride height.
f13ldy
So if I was looking for a perfect fit set of wheels, what offsets would I order?
jpboost
most perfect is probably the std 16" size. 7.5*16 and Et27 I think.
plently of people seem to run 8" fronts with around ET20 seeming most popular.
8" or 9" rears with a similar offset will work ok.
The above goes for 17's and 18's.
If you're looking for 18's check out my advert in the for sale section
f13ldy
Excellent.
This gives me something to work on at least. I was offered some 9.5" rears with an ET13 that would fit perfectly LOL...
I've seen your wheels, very nice but I want to get some 17" BBS RS's.
tobias
shouldnt have any issues with rs bbs lots of m3s on them
f13ldy
I can only see ones that are ET13 tho...
tobias
start new thread aiming at the lads that have bbs rs on their m3s. you may have better look gaetting to the bottom of it
