Rear seats question?
f13ldy
Post Wed Nov 01, 2006 9:35 am
Where my car has been tracked by the previous owner, the rear seats where left unfitted so it could get through the mot.
Now when I came to refit them the other day, I refused to believe that the bottom bench part just rested on the 2 notches and the seats backs where held on by the bottom bench part :?
Is there more to it than this, or is that it?
Does that make sense? lol.
Ziggy
Post Wed Nov 01, 2006 9:44 am
The seat back goes onto the 2 hooks, & is held in by 2 bolts in the bottom corners. The base does just push down onto those clips though - they hold it on quite solidly when you get it on properly. :thumb:
f13ldy
Post Wed Nov 01, 2006 9:51 am
Ah ha thanks.
So I'll be missing some clips and bolts then by the sounds of things.
I'll have a look on realoem to see what is missing.
Ziggy
Post Wed Nov 01, 2006 9:54 am
The clips are part of the seat base - just push it onto the lumps that stick up underneath where the seat base goes, & it'll lock into place!
Should be obvious where the bolts go too - there's 2 metal tabs with holes in em on the seat back...
f13ldy
Post Wed Nov 01, 2006 10:14 am
It maybe possible that I'm missing the clips from the seat base. As when looking at it I'm certain it was just the foam base that was resting on the metal notches.
I also remember seeing the the 2 metal rods with holes in.
Cheers for your help mate.
