i wanna see....... diamond schwartz cabbies
Estoril-5
Post Mon Oct 30, 2006 11:36 am
as the title says
just bought myself one and want to see the potential.
andyp
True Old Skooler
Post Mon Oct 30, 2006 1:13 pm
got mine but it is a standard cab
Estoril-5
Post Mon Oct 30, 2006 2:27 pm
that looks lush :cool: - doesnt look like the colour of mine tho :?
will have to check what it says on the front turret.
any other pics andyp??
cheers
mrLEE30
Post Mon Oct 30, 2006 2:28 pm
from three years ago, did the rims black, lowered it, red rear lights, SUB in the boot, new roof,black grill, smoked headlights, blue angel eyes, respray, tech 2 front/rear kit, played with the rims... awaiting my clear indicators have a look....
mrLEE30
Post Mon Oct 30, 2006 2:31 pm
front turret should read 181 for diamontschwartz mettalic
Estoril-5
Post Mon Oct 30, 2006 2:50 pm
in the first pic yours has plastic bumpers - so how did you manage to get an mtec2 kit on it??
can i put a tech 2 kit on mine???
Tyson
Post Mon Oct 30, 2006 2:51 pm
I will have my cabby next month and it's also Diamond black..But there are different kinds of this colour..One tends to be more grey then the other but a black tone will always come through..It's definately a sweet ass color..You have pics of yours?? here's a pic of mine..
E3OBM
Post Tue Oct 31, 2006 8:50 am
Richy325iTouring
Post Tue Oct 31, 2006 9:33 am
it all depends on the light with diamond black
some lights and different angles they can look green purple grey or black
Tyson
Post Tue Oct 31, 2006 5:48 pm
mine seems to have more like a greenish tint to it does it?.. you can't go wrong with this color in my opinion especially cause it can change in sunlight etc.. Sort of like cameleon but cooler 8)
mrLEE30
Post Wed Nov 01, 2006 6:25 am
I believe there are more than one type of diamond black, some have a different paint code. mine is 181 and i saw them mix it when i sprayed my car, and there is about 20% pink in there!!! :o:
That is correct, i fitted the tech 2 kit when i repsrayed the car. the rear bumper is direct replacement, the front valance/skirt requires some drilling of your metal valance and fitting of clips, and the front bumper is direct replacement. note the tech 2 kit is only a direct replacement for the plastic bumper cars and any kit will do from a coupe,4door or touring. however, the side skirts i think look ugly and are cab specific.
mrlee
Estoril-5
Post Thu Nov 02, 2006 11:29 am
how much is your car dropped by MrLEE30??
what kit did you use?
cheers
mrLEE30
Post Sun Nov 05, 2006 6:21 am
car dropped by 40mm on PI springs,
the (body) kit is a standard Tech2 kit front and rear. I only just noticed yours is the chrome bumper model (from another thread) this is unlucky as this would mean fitting the tech2 is a bit more involved, what i am not sure about is the rear wheel arches, the older pre facelift tin tops had different rear wheel arch profiles, this made fitting a tech 2 difficult and requires cutting/filling. the bumpers aslo mount differently. I understand the pre-face lift cabs suffer a simlar problem, they didn't face lift the cab until around 1990. However i have seen factory cabs called sports (or with nthe sport pack option) and they have the tech2 kit but are the prefacelift shell so it could be the case that cabs are not the same as the tin tops. I have only assisted in a tin top conversion and have no experiance of a cab conversion. good info here..
http://www.r3vlimited.com/Tech/bumper1.htm
let us know how you get on.
mrlee
Estoril-5
Post Mon Nov 06, 2006 9:37 am
so am i correct in understanding that the front bumper is easy - its just the rear bumper that is difficult??
mrLEE30
Post Mon Nov 06, 2006 10:02 am
you are correct in understanding that the front bumper requires the changing of the lower valance, cutting off the towing eye and changing the bumper mounts and installing the side mounts.
The rear is much more invlolved and really is a skilled job and requiers the assistance of a body shop/painting/filling. but basically the mounts are different so you need to make the holes in your car to which these mounts fit bigger, then fit the mounts, then fit the side mounts, then cut the bumper to fit the rear wheel arch, fill in all the gaps and paint.
mrlee
Estoril-5
Post Mon Nov 06, 2006 10:39 am
haha!
i may put the mtecII front bumper, regular se sideskirts and then try a different rear bumper or leave it as it is.
what do you think?
