E30 M3 BBS Centre caps
Guest
Post Mon Mar 21, 2005 10:18 am
Are they plastic?
Adam.
Nostrils
Post Mon Mar 21, 2005 10:24 am
Both! Part of the centre is plastic, the main cowling is metal, mine are on BBS 16's
Phil
E30 M3 - The Original Inspiration
Guest
Post Mon Mar 21, 2005 10:31 am
I've seen some sporting this part number: 36.13-1179 828 61.247.00
Are they ok for standard 16" M3 rims?
Nostrils
Post Mon Mar 21, 2005 11:42 am
That number looks a bit long!
I have check with the Online ETK and this is the graphic and part no. link
http://www.realoem.com/bmw/showparts.do ... 6c82b4f714
It shows the various colours, but the fitting is the same for 15 or 16".
I hope this helps
Phil
Guest
Post Mon Mar 21, 2005 11:54 am
I think they're the plastic ones from a 5 series. They have the same 17cm diameter so will they be ok?
