BBR Starchip... any experiences?
slowlysideways
Post Thu Sep 21, 2006 8:23 pm
OK, just replaced my ECU for one with a BBR Starchip on it, and was chatting to a mate on MSN, and when I mentioned I'd got a new ECU thats been chipped, similar to the Zone-Chip...
His reply was "not bbr starchip i hope?"
He's not elaborated yet, but can anyone tell me if they've had any experiences of them please?
I was told they are very very familiar to the zone-chip...
Do I have anything to worry about?
Dan318-is
Post Thu Sep 21, 2006 8:26 pm
I have one in my 318is
while its not the most notcable difference, it does improve top end power delivery a bit more i found, although im too use to it now to notice it
not had any problems with mine though mate!
a RR is your best bet; before and after with the chip in hand and the original EPROM
HTH
slowlysideways
Post Thu Sep 21, 2006 8:28 pm
hmmm my original ecu is bust! LOL so no chance of that
i don't particulary mind, i just didnt want any adverse affects
it's only a track car, so MPG certainly doesn't bother me
on a trackday, my standard ecu got me 150 miles from Ԛ£50 petrol! LOL
Dan318-is
Post Thu Sep 21, 2006 8:33 pm
:rofl: thats no good
well the only adverse effects iv ever had was from the first chip i had ( i wont name it) but it was a major one
generally the symptoms i had weere above 5000rpm, black smoke was emitted (overfuelling i presume) and often a large amount of misfires towards the end of the rev range. and dire fuel consumption
tbh if its for a trackcar unless it seems slow stick with it imho!
slowlysideways
Post Thu Sep 21, 2006 8:36 pm
Do you know if the BBR-Starchip is similar to either the Wild or Mild Zonechip?
Characteristics I mean, and if so - which one is it nearer to?
Dan318-is
Post Thu Sep 21, 2006 8:38 pm
No idea dude! zone chips arent available for the 318is so i havent the foggiest!
i dont no of anyone else on here with a BBR startchpi. there must be someone!
Post Thu Sep 21, 2006 8:39 pm
ive always thought of the BBR as a 1/2 decent generic chip..
slowlysideways
Cheers for your help anyway mate...
Hope someone can shed some light on this for me :)
slowlysideways
Post Thu Sep 21, 2006 9:00 pm
I'll go out for a 'test run' in a mo, and see for myself lol
Basically, the reason for the initial post was because he said "not a bbrstar chip i hope"
Basically a friend of his had alot of problems with his, and it wouldn't even idle...
Mine idles perfect so I'm hoping it drives well too... hoping it's not upped the rev limit by too much
slowlysideways
Post Thu Sep 21, 2006 9:40 pm
Just been out in it, no noticeable difference, but thats cool - thats not the reason I bought the ECU.
It was just going to be a bonus if the difference was noticeable.
Redline is still at 6.5k too. :)
Dan318-is
Post Thu Sep 21, 2006 9:41 pm
My limiter was a lot higher i must say!
slowlysideways
Post Thu Sep 21, 2006 10:04 pm
Probably not got the said BBR Starchip in then afterall.
Still not fussed, just glad I've got a working ECU :)
Ant
Retired Team Member
Retired Team Member
Post Thu Sep 21, 2006 10:08 pm
Tech 1's have a lower limit due to the flywheel mounted TDC referance peg, much over 6.7K andit departs from the flywheel, usually leaving a nice hole in the bellhousing
nothing wrong with a BBR starchip guys, its old skool cool
look @ it this way, fit chip and "wow its got 30hp more" is not gonna happen, TBH when I map I try and keep the factory smooth feel, and still get the gains, a peaky delivery can be had by actually reducing the power below say 3.5k, then put the ignition timimng back to "correct" and feel the "extra power" over 4K
can you see where I'm coming from ?
A good remap is one that maintains the stock drivabilty , but with more Hp and TQ right through the rpm range, with enhaqnced pickup and possibly reduced fuel consumption.
more of the same if you will.
Chipping and remaps are a science, number input to give a desired output, the "feel" is where the tricks are.
HTH
dazleeds
old skool raver
old skool raver
Post Thu Sep 21, 2006 10:23 pm
hiya mate
glad you got it ok
first off if there is a prob or your not happy just say fella
i never tried the chip as i said so will take it back if any probs
had a look online but couldnt find much info reg bb etc
heres a site i found but dosent say much :roll:
http://www.morego.co.uk/starchip.php
alsp managed to find the details for bbr
http://driveitfast.com/tuning/tuning.as ... ubCatID=41
www.oldskoolfantasy.co.uk
slowlysideways
Post Thu Sep 21, 2006 11:09 pm
daz - i'm more than happy.
i just needed a replacement 073 ecu, which i have got
the fact it has a bbr chip is just an added bonus :D
still a very happy man as far as i'm concerned
next stop... donington again :)
