Timing belt.
gooner1
Out humping Reindeer
Post Mon Aug 28, 2006 5:49 pm
In the middle of changing above, got old one off and have fitted new one but now cant get TDC marks to line up.Really dont know how or what has moved but am i right in thinking if i move cam to left or right to line up marks this will be ok. Grateful for any help.
gooner1
Post Mon Aug 28, 2006 6:02 pm
Whoops meant to say crankshaft, cam mark is spit on.
DRIFTBOY
Post Mon Aug 28, 2006 6:08 pm
Yeah, that's right. As long as all marks line up as they should.
Best to then tighten everything and turn the engine a few revolutions by hand with a socket on the crank pulley and make sure it's all still in line.
gooner1
Post Mon Aug 28, 2006 6:12 pm
Cheers mate, best to move crakshaft back without belt on i take it.
DRIFTBOY
Post Mon Aug 28, 2006 6:17 pm
Yeah!
Looks like Argos is on the case with better info though!
gooner1
Post Mon Aug 28, 2006 6:20 pm
Thanks Argos, its a m2o.Had all marks set up before i took old belt off but after fitting new one the marks on the crankshaft end is way out.So have now relaesed tension on the new pulley and have taken belt off.
