windscreen
jon_pure_british
Post Sat Aug 12, 2006 12:21 pm
can i pop this out of my breaker with ease? do i only need a few flat heads?
ta
jon
Clacton-On-Sea
Essex
smithy318i
Post Sat Aug 12, 2006 12:35 pm
flat heads?
to remove the windscreen, remove metal clip and the V shaped plastic insert from around the seal, then push the top of the screen with your feet, from inside the car.
jon_pure_british
Post Sat Aug 12, 2006 12:44 pm
yea i thought maybe lever it out,
i may aswell keep it as a spare for my car... wheres the metal clip? are these V clips spaced out all around the windscreen ?
cheers smithy
jon
Clacton-On-Sea
Essex
Chris-W
Post Sat Aug 12, 2006 12:45 pm
....just not too hard. Or at least have someone to catch it!
jon_pure_british
Post Sat Aug 12, 2006 12:50 pm
thanks :D ill make sure theres someone to catch the flying windscreen, when it stops raining :cry:
Clacton-On-Sea
Essex
smithy318i
Post Sat Aug 12, 2006 12:56 pm
the metal clip is at the bottom of the screen, then you just pull the plastic like a snake.
DONT LEVER UP THE EDGES, OTHERWISE IT WILL CRACK.
jon_pure_british
Post Sat Aug 12, 2006 12:58 pm
smithy318i wrote:the metal clip is at the bottom of the screen, then you just pull the plastic like a snake.
DO NOT LEVER UP THE EDGES, OTHERWISE IT WILL CRACK
thanks mate! :wink:
Clacton-On-Sea
Essex
