333i forsale
stuartgallafant
believe it or not i don't think they are alot quicker than a good 2.7! it's the 3.5 B6 real deal alpinas which shift even by todays standards!
TheKaiser
Mmm, that'd do! One day when i have lots of money....
eun
very beautiful though
Euro3
If it had this set up it would be really quick
1985 BMW 333i
Year 1985
Make BMW
Model 333i
Engine Location Front
Drive Type Rear Wheel
Weight 3100 lbs | 1406.2 kg
Performance
0-60 mph 4.5 seconds.
Engine
Engine Configuration I
Cylinders 4
Aspiration/Induction Turbocharged
Displacement 3210.00 cc | 195.9 cu in. | 3.2 L.
Horsepower 450.00 BHP (331.2 KW) @ 5000.00 RPM
Torque 520.00 Ft-Lbs (705.1 NM) @ 3000.00 RPM
HP to Weight Ratio 6.9 LB / HP (Vehicles with similar ratio)
HP / Liter 140.6 BHP / Liter
Vehicles with similar horsepower and weight
Transmission Information
Gears 5
Transmission Manual
1985 BMW 333i
Year 1985
Make BMW
Model 333i
Performance
Engine
Cylinders 4
Gears 5
Transmission Manual
323i_rare
What engine is that?Euro3 wrote:If it had this set up it would be really quick
1985 BMW 333i
Year 1985
Make BMW
Model 333i
Performance
Engine
Cylinders 4
Gears 5
Transmission Manual
jonb
you put a larger cam in it.......323i_rare wrote:How do you cam up a 3.5?
euro 3. you got the wrong spec there my man. this car is not turbo"d.
Euro3
745i turbo motor was an option for the 333i in SA. You can acutually bump it up with fpr, injectors and cam and get 550 easy. 600 max.323i_rare wrote:What engine is that?Euro3 wrote:If it had this set up it would be really quick
1985 BMW 333i
Year 1985
Make BMW
Model 333i
Performance
Engine
Cylinders 4
Gears 5
Transmission Manual
I am thinking about putting this set up in my 88 535i.
Here is what my car will look like when I am done with the custom ABS body kit (pshoped for conceptual purposes) should be sweet with 5550hp.
Euro3
I said IF it it had that optionjonb wrote:you put a larger cam in it.......323i_rare wrote:How do you cam up a 3.5?
The 745 turbo motor was NEVER an option in a south african 333i , though no doubt several have been turbocharged by the after market including a sapphire blue (?) one in this country which i believe the specs above pertain to.
Euro3
Here is the article I was reading when I started looking at 333i's long time ago. Maybe it was a joint venture with a tuning company and BMW.pacerpete wrote:The 745 turbo motor was NEVER an option in a south african 333i , though no doubt several have been turbocharged by the after market including a sapphire blue (?) one in this country which i believe the specs above pertain to.
BMW 333i Turbo Specifications
Manufactured by BMW South Africa in 1986. Car No 51 of 204.
Displacement 3210cc
Engine Modifications Lightened, balanced & fully blueprinted engine, Mahle pistons, Carello con rods, Nitriden crankshaft. Cylinder Head gas flowed & ported, Cosworth 500 water-cooled race-balanced turbo charger with 360° thrust bearing & modified wastegate, Intercooler. Redesigned & ported exhaust manifold & twin 2Âa" exhaust system. Upgraded fuel injectors
Maximum output 450bhp
Compression Ratio 6.8:1
Engine Management System Zytek, with 3-bar map sensor. Programmable
Gearbox M5 Getrag Sport
Clutch Sachs racing (6-series)
Final Drive ZF Disc - Limited Slip - 25% Locking
Suspension Alpina/Bilstein
Brakes Hydraulic pump ABS
Front dual Ventilated & Grooved 11.7" Alpina Discs with Alpina pads.
Rear modified 323i Discs with Alpina pads
Rims Alpina Light Alloy 7J x 16
Tyres Front & Rear: Yokohama AVS-1 205x50x16 ZR
Bodywork Original M-Technic
Other Modifications Hartge kevlar vented bonnet, Air box, Air conditioning
jonb
euro 3
it sounds like that spec has been taken from a magazine feature, of the same car that pete speaks of.
he was at donington about 6 years ago. i remember speaking to him(he had a stutter so i was there for a while). i remember it was fosale. 10k i think...
it was turbocharged. and had around 450bhp.
Thats the same ffffffffffucken car !
Kos
it was in bmw car years ago with another white one, they did a whole write up on them
the owner of the saphire blue one used to have an RS turbo and when to upgrdade to a cossie, but bought the 333i which was tubocharged by the previous owner
AVA based oin scotlan tuned it up to 450bhp i belive
bmpaul
lovely motor just need to have one. no need for a reason other than i want one!
E39 530d M-sport- quite nippy
Herrity
- Location: Liverpool & Leamington spa ! Drives: Mercedes 190 cosworth & 1990 325i touring
What is that car worth ?
