Short Shifter - Happy Days!
Dominitry
Post Mon Aug 07, 2006 2:58 pm
Well, i was tempted to buy a short shifter for my sport, turns out i already have one :D
Wonder what other secrets my car has :?
Couldnt tell the difference before but after trying out Dunx's SE's shift you can notice it ALOT! lol
Richy325iTouring
Post Mon Aug 07, 2006 4:38 pm
dunxs is probably just worn
ive driven that sport of yours and there def isnt a short shift on it fella
Dominitry
Post Mon Aug 07, 2006 4:45 pm
The difference isnt mild though, soon find out ;)
Geeman
Post Mon Aug 07, 2006 4:48 pm
I heard you got a short knob anyway... :wink:
BIGJO
Post Mon Aug 07, 2006 4:59 pm
:lol: (Geeman)
Richy325iTouring
Post Mon Aug 07, 2006 5:08 pm
lol@ gee
craig trust me there isnt a short shift on the sport fella
dunx is prob as worn as that shitter 320 i had
the sport is about the same as my se
Bob_S
Post Mon Aug 07, 2006 5:10 pm
I took the plunge and bought the 1.9 shifter for mine at the weekend cant wait
Bollocks to this 24v scrap!
BIGJO
Post Mon Aug 07, 2006 5:17 pm
You sure you're not confused by the short gear ratio with the shortshifter fella (Dominitry)?
Sorry, just thinking that you'll definately be able to tell the difference with a shortshifter & without because the changes are quite significant! Nothing like before.
Regards, BJ.
Dominitry
Post Mon Aug 07, 2006 5:31 pm
Well thing is, i''ve barely driven the sport so im not sure, hmm, dont know anyone else with a sport to check :?
Geeman, dont make me send you photos of my penis!
Dunx
Post Mon Aug 07, 2006 5:44 pm
Dominitry wrote: Geeman, dont make me send you photos of my penis!
Didnt think you got that macro lens yet mate?
NIX
Post Mon Aug 07, 2006 5:56 pm
How hard is it to fit a short shifter/z3 shifter? How long do you think it would take for a moderate novice to do so?
Bob_S
Post Mon Aug 07, 2006 6:40 pm
it's in the zone articles mate, I cant see it taking more than 2 hours
BIGJO
Post Mon Aug 07, 2006 7:13 pm
Dominitry, i have a Sport Mtec II & it's basically the same set up. Obviously there are differences but nothing that concern your gearbox fella.
Anyway, the gear ratios on these sports are shorter than normal 325's which, helps you increase your speed quicker due to the ratios. If you had a shortshift on the car then it'd take a few days for you to get used to it. You'd find it difficult for a couple of days. Also, you would know if you had a shortshift fella as you may not have experienced anything like it!
I'm sure someone from this zone will be able to help you with expert advice. However, the shortshift is a must-Z3 2.8. It sure makes a difference!
Regards, BJ.
Dominitry
Post Mon Aug 07, 2006 7:19 pm
I know about the gear ratios mate, but the throw when changing gear is very short compared to a dunx's e30, im not sure if dunx's may be worn but Chaos said he always thought my sport had a quick gear change, and hes got a low milage e30 so obviously not worn, i have no idea how to tell because i've never driven another sport, but the difference to dunx's SE is not mild, its huge.
Dunx
Post Mon Aug 07, 2006 7:25 pm
Compare it with the vert ?
Post Mon Aug 07, 2006 7:29 pm
a good standard lever with all the bushes ok is not that bad imo, but the 1.9 lever is a joy to use again imo. 2.8 is a bit too harsh
Dunx
Post Mon Aug 07, 2006 7:46 pm
btw - has anyone tried the 2.8 with a weighted selector rod yet?
bigkev
Post Mon Aug 07, 2006 8:23 pm
gonna make my own will let you know how it goes 8O
jamesc
Post Mon Aug 07, 2006 8:48 pm
NIX wrote:How hard is it to fit a short shifter/z3 shifter? How long do you think it would take for a moderate novice to do so?
Fitted mine at the weekend and it was very easy, though I already had the exhaust and prop off :D
James
jamesc
Post Mon Aug 07, 2006 8:51 pm
Oh and anyone going to fit one, its well worth fitting a new shifter bearing (number 4 below), mine was *really* knackered. Can't remember if it says that in the tech article but I thought I would point it out anyway because it will make a big difference.
James
NIX
Post Mon Aug 07, 2006 9:35 pm
Thanks mate!
Geeman
Post Tue Aug 08, 2006 8:41 am
Craig... what the hell are you doing taking a picture of your own appendage...? Surely not! :eek:
WerkdE30
Post Tue Aug 08, 2006 9:06 am
ive driven a z3 n i didnt find the shift to be all that short i have a short shift fitted to my e30 n its literally a click between each gear. its the shortest shift i have seen and i have seen a few. hartge gear knob makes it all the sweeter.
Incitatus
Post Tue Aug 08, 2006 9:13 pm
The question's always being raised about the difference between the 1.9 and the 2.8 shift lever, and it's difficult to answer objectively, so, with a rush of blood the the head, let's have a go at quantifying it :eek:
On mine I have the 2.8 shift lever, and measuring with the gear knob removed ( as that gives us a nice fixed point), and from the top and centre of the shift lever, the travel from first to second is 6cm. With the gear knob in place (Z4 style) it's 7cm
If someone who has a 1.9 shift lever could measure from the same points people could make a judgement which one is for them (and maybe compare the standard shift too). Maybe we could add the results to the technical article too?
Bought: Obtain in exchange for payment. Brought: Come to a place with (someone or something).
These words are NOT interchangable....!
stevetigger
Post Tue Aug 08, 2006 9:16 pm
jonb
Post Tue Aug 08, 2006 10:14 pm
Dominitry wrote:, im not sure if dunx's may be worn but Chaos said he always thought my sport had a quick gear change, ].
sorry craig.
but chaos isnt really a good judge on things.
where has he gone anyways???
craig you still driving that sport with the hero damage?
Ziggy
Post Tue Aug 08, 2006 11:15 pm
Am I missing the point here? Surely it'd be a bad thing to discover that you already had a short shift, & therefore didn't have the oportunity to improve it so easily? I'm assuming that's the reason you were considering one anyway?!
BIGJO
Post Wed Aug 09, 2006 12:19 pm
2.8 shifter all the way baby :thumb:
