1st of you have all been very helpfull with the other questions i have asked.
What i would like to no now is what suspension is the best set up for my E30 325i
I was thinking billstien
Ok another question( suspension )
Dee
SIT BACK HOLD TIGHT & SHUT UP
Darryl
Geeman
The BEST set-up...? Do you mean shocks, springs, or both?
Plenty of people would argue that the H&R set is the BEST...
Eibach is pretty good too.
But the best set-up would be coil-overs. Depends on your budget...
How much do you intend on spending...?
Giles.
Giles.
Dee
I mean the hole lot spring shocks
Coilover are not for me so thats out of the question so whats next on your recommendations then
Darryl
Geeman
Well, going from what other people have found, the H&R Cup set takes some beating.
You can mix and match the shocks and springs though, Eibach springs and Bilstein Shocks are a very good combination, as are the adjustable Spax shocks, though the Spax springs are quite hard and result in a rough ride.
Wouldn't go for a cheap set. I made this mistake and bought a 60mm Apex shock and spring kit for my convertible. Cheap... yes. TERRIBLE ride quality though... very choppy.
I made the mistake of buying an FK coilover system for my track car. What a waste of Ԛ£600. Might as well bought a set of PI springs. Wish I'd gone for the H&R set-up now... Oh well, you live and learn.
I'm sure other people on here will join in and advise you as well, but I'm betting 80% of them will recommend the H&R set...
HTH
Giles.
HTH
Giles.
- Homo Hair
H&R is the road im goin down...
Geeman
I got some H&R springs coming, using standard Mtech Shocks... (on the Sport road car that is)
Dee
Thanks Geeman
I havent even picked the car up yet and already i bought some alpina rep rims and will be bying Scorpian exhaust next week
Darryl
Karan
h and r cup kit is prob the best setup for road use and occasional track...
only prob is the 60/40 drop the kit gives... can prove difficult on some big bumps
but ive tried bilstien/koni/eibach in the past and the h&r is far superior it has to be said
or u can do as giles said and get the h and r springs with standard bilstiens.
Karan
Karan
Bharat
Don't forget, if budget is a little tight, then Sachs Boge shocks are damn good too, M-Tech specifications as well. With Eibach springs - very good ride quality, drop of about 30-40mm.
As has been mentioned, H&R Cup kit is an excellent choice for a little more than the above set up.
I would also budget for changing the mounts all around, and the 'spring pads' for the rears.
325i Motorsport Edition convertible - gone, but not forgotten.
Dee
Thanks lads you all have been a great help
Darryl
