happens to my E30!!!!.........
dont know how bad the damage is til daylight....i dont even know if i could sleep tonite...AHHHHH!!!!!!!
I witnessed the same thing on E30Adam's FPR, rip it out, they are a fire hazard as you have just witnessed....E30_Pilot wrote:small fire,fuel leaked out from the FPR...I was able to put fire out quickly.lucky it happen in front of work.
The standard one is held in place by two bolts.JCB wrote:i was horrified to discover that this little device is just "friction fit" into the injector rail. i inadvertently removed my FPR when stipping the engine as i couldnt get the fuel hose off. i cant believe how badly it seems to be engineered considering the consequences if it comes slightly dislodged.
1) how can it be removed - ie what do you replace it with ?
2) if there is no FPR what regulates the fuel pressure (i have a racing fuel cell and swirl pot so do i need it anyway ??
thanks
