Why are my headlights full of water?
William
- Location: Home:Suffolk, Uni: Cirencester, Gloucestershire
Simon
Are they brand new lights? Or did you buy just the fronts and make your own?
William
Simon
? Why did he paint the surrounds...they should have already been black if they were genuine!?William wrote:They are brand new units from Germany Simon, hence the confusion really because they should be perfect. The only thing is the guy who fitted them also painted the surrounding rings black to match the grills, and that may be the source of the problem??
Demlotcrew
William only got the front glass sections me thinks.
Andrew
Andrew
William
William
Chris-W
Did you use Hella backs? If you used Bosch they won't seal.
kidsinister
William
Demlotcrew
William you need to get Hella backs, all E34s have them and they will fit.
Andrew
Andrew
Chris-W
Don't make fun - he's been to Hella'n back over these lightskidsinister wrote:Are they on dipped beam?
*Gets coat*
*leaves*
nasir325ic
thats rght mate, get yourself some e34 backing units, and this should solve it
coz initially when the bosch units were fitted the driver side only fitted upside down, which meant the lights were
facing the sky, and could not be adjusted enough to bring them down, so we changed the backing unit for the
driver side, and when the car got washed the passenger side got steamed up
William
Demlotcrew
Any good scrap yard will have a E34 in stock.
Andrew
Andrew
mrLEE30
you could just try sealing the glass/backing joint area with high temp black silicone, remove the black outer rings rings and you will see the joint. This sealed area would be hidden by the rings once on the car anyway, this joint is the only place where water can get into the light unit (unless its getting in from the rear bulbholder area). much easier than swapping the lenses.
but if you want help doing the lenses then here's an article i wrote earlier
http://www.e30zone.co.uk/modules.php?na ... hhella.htm
duffs17
brilliant!Chris-W wrote:Don't make fun - he's been to Hella'n back over these lightskidsinister wrote:Are they on dipped beam?
*Gets coat*
*leaves*
stuartgallafant
Bob_S
it is funny but not the situation I was going to say e34's have em
Bollocks to this 24v scrap!
