mic1
Tue Jul 25, 2006 11:54 pm
hi
have noticed some parts i.e. lowering springs, induction kits etc are advertised for 318/320/325 and the 316's are seperate. why is that? idve thought they were the same, just different size engines
mic
smithy318i
Wed Jul 26, 2006 12:17 am
hi mic
because of the weight of the different engines, springs are different from model to model.
as are air filters (not worth buying one for an M40 BTW)
mic1
Wed Jul 26, 2006 1:01 am
but the air filter would make it sound a little 'nicer' tho wouldnt it at least
Kos
Wed Jul 26, 2006 1:03 am
they all fit but a 60mm spring on the front of a 4 pot engine will give you nearer a 55mm drop. spring rates vary but on a daily drive and you are doinig just to give the car a better look it aint worth worrying about
Zayyan
Wed Jul 26, 2006 1:11 am
Focussing on springs...
Any 4-cylinder springs will give the stated drop on any 4-cylinder E30 as the 4-pot engines are all the same weight (give or take a couple of kg).
You shouldn't see springs advertised for 318/320/325 as the latter two have a heavier engine and will give a different drop.
As Kos says, the difference is negligible, but it's certainly "safer" IMO to use only springs desgined for the car you're putting them on.
Kos
Wed Jul 26, 2006 1:26 am
the spring wont fall out somsafety not exactly an issue, as long as thet are not cut heated of cracked they will be fine.
dips 346 has a few set of springs, send him a pm
Zayyan
Wed Jul 26, 2006 1:28 am
Kos wrote:the spring wont fall out somsafety not exactly an issue, as long as thet are not cut heated of cracked they will be fine.
They obviously won't fall out but using springs designed for a heavier engine is never going to be the way to do it, unless you're a fan of bodging.
mic1
Wed Jul 26, 2006 1:34 am
oh i wasnt planning on doing springs to be honest, at least not for a while and even then it would just be for looks more than anything. havent bought a bmw yet, hopin to pick up the 316 on saturday assuming he still has it by then.
nice to see some people are local tho
Kos
its not bodging, cutting and heating is, which i've done before, but even that can be safe if done the right way.
the spring rates may differ slightly, but the difference is more so on a cabrio and tourings. most springs are designed to fit an e30 full stop, i'm pretty sure even the H@R ones are like this that why the give a 60/40 drop an a 2.5/2.0 and only a 55/35 on a 316/18/IS same goes for KW, why dont they they do a 60/40 for a four pot engined car??
the progression of spring comes into effect on hard cornering
i've had lots of e30, and change suspension set ups from car to car with no negative or dangerous compromises (well maybe a compromise in comfort only!)
good luck with the car mate
dobbie82
- Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Wed Jul 26, 2006 12:33 pm
smithy318i wrote:hi mic
Why not worth buying an air filter? am I missing something? (apart from the £11 or so i just paid BMW for one!)
julianm40
Wed Jul 26, 2006 1:21 pm
I found with my old 318i, putting an aftermarket cone air filter made absolutley no difference whatsoever.
Julian
dobbie82
Wed Jul 26, 2006 1:26 pm
oh do you mean no point with an aftermarket or no point in a filter at all?
Wed Jul 26, 2006 2:22 pm
Standard E30 air filter, changed regularly, flows more than enough air for anything up to a lightly modded 2.5.
£11 sounds a bit steep for one though - dealer price really that high? About half that from GSF/Eurocarparts, IIRC.
