Been to Bexley's and got a list of work as long as my arm that "needs doing". Thought it wise to get a second opinion.
Where else, other than Bexley Motor works...
Guest
...can I take the M3? I'm sure I read somewhere that there was another specialist in my neck of the woods. That being SE London and Kent type of area.
Ant
- Retired Team Member
try Hartlake , gravesend area, good a reputation as anyone.
dont go ML, they'll bend you over
Email FTW
Rich_W
Sadly it seems that the specialists are of the "Old skool" mentality. List everything and get the hump when the customer dosen't fancy a grand and a half bill!
Even modern dealers have some form of priority rating for work. So "Brake pads 99% worn" will be high and "Exhaust box just starting to corrode but not blowing" will be low.
I only want the bare bones of the servicing done by a specialist. Simply for the invoice to show the next owner. Everything else I'll do myself cos I can
What were you listed btw?
Guest
Oh you know, not a lot, just:
HT leads
Air hoses
Electric fan
Engine tune
Propshaft coupling
Gearbox coupling
Oil filter housing
Front crossmember
Power steering belt
HT leads
Air hoses
Electric fan
Engine tune
Propshaft coupling
Gearbox coupling
Oil filter housing
Front crossmember
Power steering belt
Rich_W
Surpised that Inlet Blocks arent on there or Suspension bushes. They tend to be the things that go on these cars.
In fairness, a lot of that you could do yourself. Leads, Hoses, Fan, Couplings and PAS belt.
Depending on what you have at home you might be able to so the oil housing and the cross member.
Engine Tune is after the other bits anyway. And that will only cost a couple hours labour at most. So its not too bad really.
Guest
I'll try and do some myself then. The quote weighed in at about Ԛ£1300 so I had better start diggin'! Just bought some ht leads so I'm getting there!
Anyone else got anything else on offer?
M3RAGS
try my mate Phil, at Birds....
He works at Birds as well as does his own stuff out of birds...
what he doesnt know about e30 m3's you could fit on a postage stamp.....
give birds a call and as for phil crouch.....
Sideways S14
M3RAGS
btw, phil started Hartlake BMW!
Sideways S14
Rich_W
You like Birds dont you Rags
About the same amount that I dislike Bexleys
M3Jimbo
looks like a big little one?!
Ziggy
Not very! 1/10?!Simon13 wrote:looks like a big little one?!
Jesus325iTouring
- Frog freak !
LOL,I had to look twice at that!
