Virtual pint to the man who tells me
M3 LSD Oil - what is the spec?
Paulsimon8
Can anyone please enlighten me asto what the correct oil is for the E30 M3 LSD?
Paulsimon8
surely someone knows which oil to put in an lsd
Demlotcrew
i think its like 75w80 and its must be good for hypoid gears and have a LSD additive.
But i cant remember off the top of my head.
Andrew
Andrew
I used Castrol B373, SAE 90 in mine. About £5 per litre, high pressure mineral based
The dealers use Castrol SAF-XJ, SAE 75W-140. Ive heard of people paying upto £22 per litre for this stuff though
but it is fully synthetic
Or you can get Comma LSD oil from any decent motor factors at about £3 per litre
HTH
HTH
M3Compact
SAF-XJ is the modern BMW recommendation, when the car was built B373 was the BMW spec' oil. I've used B373 in dozens of these diffs without problem.
£4 a litre V £17 a litre, you pays your money and takes your choice.
Paulsimon8
Cheers people
Next question - how much oil is needed to fill the diff to the level it is normally at, from empty
(IE, a fresh oil change)
stuartgallafant
Paulsimon8
Cheers boys
