ENGINE NUMBER?
bennyboy
i have already asked this question but where is the number on the block? i was told by someone on the forum that it was on the 3rd cylinder on the inlet side. i had a quick look the other day but couldnt find it. do i need to take any parts off to view it or just get my eyes tested?
16V IS engine!!!
Templ8e30
The engine number is usually on the inlet side right down above the block/sump joint stamped into a raised area of the block.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
cliffybabe
- Powered by Nelly
Does this apply to a M20 ??
Templ8e30
Definately applies to the M20 but also to the other E30 engines iirc.
Cheers,
Iain T
Cheers,
Iain T
stuartgallafant
cliffybabe
- Powered by Nelly
stu if i get the nuber can u tell what the lump is???
stuartgallafant
cliffybabe
- Powered by Nelly
cheers mate
stevetigger
I thought eightstuartgallafant wrote:its about 9 numbers long isnt it?
cliffybabe
- Powered by Nelly
im gonna check tongiht on mine
stuartgallafant
