wheels for e30.
Geeman
- Contact:
The stud pattern is the same, but the offset means that they won't fit the E30 without spacers... and even then, they might not fit correctly. If you've got one to hand, try it and see.
bottlecapE30
The center bores are different the mini is 1mm smaller than the e30 you would have to have it bored out 1mm i have seen it done.
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
