these discs any good
thesaint
Post Sun Jun 04, 2006 8:14 pm
http://www.ekmpowershop3.com/ekmps/shop ... ductid=361
the above dsics any good? any other recomendations?
1986 325i - Gone. 1993 318i touring, m52 in the planning stages.
Lordschleife
Post Sun Jun 04, 2006 9:33 pm
Bloody pricey! 8O
Try ATE powerdiscs from ECP, or stick to std BMW
Cheers,
Robin
Post Sun Jun 04, 2006 10:21 pm
You only need grooves or holes in discs if the pads produce gas when hot, giving a hovercraft effect.
Modern road pads don't gas, so no advantage.
Bailey
Post Tue Jun 06, 2006 7:44 pm
hi there,
i always thought that drilled and grooved discs helps keep the disc cooler under heavy breaking regardless of the pads etc. i did hear though, that cheap drilled discs arnt recommended, because theres a chance that they can crack around the holes.
Post Tue Jun 06, 2006 7:47 pm
nope.. vented bit does that
in theory grooves clean the pad, drilled discs stop gas build up. all drilled discs will crack.. seen it on porsche ap setups
in practise, bmw discs are man enough
Bob_S
Post Tue Jun 06, 2006 7:55 pm
BM discs are £36 plus the dreaded minus discount, all you have to do is ask!
Bollocks to this 24v scrap!
