Need some help DOWN UNDER.
tassiedevil
Just about to start preparing my 325is for a respray and wondering how hard it is to remove sunroof. I will have front and rear screens out if thats any help.
mrLEE30
open sunroof about half way, prise open the inner sunroof trim from the leading edge of the sun roof with a screwdriver or similar, do it carefully as they are prone to breaking, try to use the tool as close to the plastic tab as possible.
once tabs opened close roof and slide the trim back into sunroof cavity. then you will see the holding nuts on each side, 3 on each side.
remove and sunroof will come out.
it is suggested not to reuse these nuts when refixing as they are thread lock type. get some more or they may vibrate loose in the future.
lets see some replray pics!
mrlee
mrlee
ian332isport
Welcome to the Zone, but can you please reduce the size of your Avatar - It's HUGE
Thanks,
Ian.
Thanks,
Ian.
