It currently has a standard 325i exhaust on (3-piece), any recommendations for a replacement gratefully received, also advice on where to get hold of them - Manchester area.
Off you go...
If you're replacing the whole system (apart from the manifold), you can swap between 2 & 3 piece systems with no problems. The only thing to be aware of is that there are 2 sizes of manifold flange, so you need to make sure your front section will fit your manifold.kidsinister wrote: Incidentally, it seems to be a 2-piece job (which was 88> I believe...) does it matter (car is pre-facelift)?
