Hi Guys
Gearbox is rumbling - have a replacement diff, and need to change the brake fluid - so...
Whats the best stuff to use for each?
Q
Which oil? Gearbox, Diff, and Brake Fluid?
Quaser
ed325i
Gearbox is SAE 80 for manual box, Diff is SAE 90 but if its a LSD I think you use diffrent oil, Brake fluid is DOT 4.
http://www.opieoils.co.uk/
ED
ED
Quaser
Ok - thanks for that Ed
What about performance makes of oils?
Is redline anygood? - the blue brake fluid stuff i recall is also supposed to be good but expensive. Any others?
Q
Q
ed325i
click here it find out > http://www.opieoils.co.uk/
