does LHD drive exhaust fit RHD?
Hap
Post Wed Mar 02, 2005 2:19 pm
as above would this work or would the system be the opposite side round if you get what i mean and not marry up with the RHD front manifold?
Hap
Post Wed Mar 02, 2005 2:21 pm
i dont see why it wont fit.. the system itself should be the same as the manifold wont come out a different side of the engine!!
Hap
Post Wed Mar 02, 2005 2:31 pm
so a lhd drive german box box thru to centre box will fit a rhd car? would the lhd exhaust sit in the same poistion as would a rhd counterpart?
Post Wed Mar 02, 2005 2:40 pm
i would say yes!! do you have any pics to compare?
the only difference between lhd and rhd as far as im aware is where the driver sits! The chassis/shells themselves are the same..
Nostrils
Post Wed Mar 02, 2005 2:49 pm
I only know about the E30 M3. If this is converted to RHD, then the manifold has to be replaced because it would foul the steering column!!
I wonder if it is the same with other models!
Phil
E30 M3 - The Original Inspiration
Hap
Post Wed Mar 02, 2005 2:51 pm
i cant send the pic bt when i look at the lhd drive system with the pipes it looks the "wrong" way round to my system. anyways cheers feck it
Hap :wink: [/quote]
Toby_Unna
Boost Junkie
Post Wed Mar 02, 2005 2:57 pm
the m3's only like that because it has a special tubular exhaust manifold.
Hap look on the onlike ETK parts thing if you need to check, but i'm sure the exhaust manifold's on the same side of the engine.
even though some alpina etc conversions used a different manifold when built as RHD for steering column clearance reasons, the rest of the system should be the same.
Hap
Post Wed Mar 02, 2005 2:59 pm
ok cheers guys ill have a look
jonb
Post Wed Mar 02, 2005 4:00 pm
lhd exhuast manifolds are complete different than the rhd ones. they are a 2 piece. thus making the downpipe different.
Hap
Post Wed Mar 02, 2005 4:05 pm
i think jonb is sort of sayimg what i think.
Post Wed Mar 02, 2005 5:55 pm
Have you and Simon gone against the quicksilver option hap?
Hap
Post Thu Mar 03, 2005 4:27 pm
nah i seen a genuine backbox on german e bay went for a messly 21 euros :cry:
Moofles
Post Fri Mar 04, 2005 1:25 am
someone elaborate more on the difference between lhd/rhd, prior to this i'd hav said 99.9% sure they were the same, what's different? (details please :D )
'08 GSX-R750, '02 CBR600F, and a beast of a Focus 1.8LX...
My old sig :( - http://img52.imageshack.us/img52/2652/funnyface8eg.gif
