look at the pics
i went out in the car on wednesay eve, everything was fine with it. some passer by complemented my rims and i think the fcuker jinxed my wheels
only done about 5000 miles since i had all four changed, the fronts are all fine.
The rear tyres are finished, they look ok until you look at them from the inside where they are so worn that you can see the metal strips inside the tyres because of the negative chamber.
The story goes on, i thaught i might have a slow puncture but that wasnt the case either. I went to fill the tyre up wth air but no air seemed to be going into the tyre. I gave up and decided to put my spare onto the car. It wa.s when the wheel came off i realised what had happen, the tyres were bold on the inside and had enough tread on the outside.
so i now need two tyres and a refurb on my wheels
