Called me up saying that it is going to fail on rear suspension bushes and rust ..
Went and had a look with them. OK so I knew all the rear suspension needed new bush's but their not split or anything, I doesn't drive badly either....
Then they point to rust on the battery tray, is this part of the MOT? Its not terminal only surface!
Then to a bit (i mean like the size of a 10pence piece) by the gearbox and that the square "jacking points" at the front at a bit of rust around them.
They then told me that another garage might pass it
Didn't charge me at all which I think was very honest. Going to take it to this other garage on monday...
Anyone else had this experiance?
