dark_sounds wrote:eliminate the metal blockers and u should get slightly more bass into the cabin
If you can get the front of a
12" driver into the cabin, facing toward you, the efficiency of the bass
will be so high that you should not need that big an amp.
JBL supply several cabinet/baffle design plans with their drivers for
raising efficiency still further .
I reckon a single 12" where the ski-port is would be a good way to go,
you'll never run out of bass and you can hide it completely by flipping
up the central arm rest. (Assuming the back seat is how I imagine it).
You do not need to cut any of the bulkhead, the port area is enough.
Just be careful sealing the driver to the baffle. As far as efficiency goes,
you'll lose 1/2 the sound anyway as the speaker has a back and a front.
This calculation is based on an infinite baffle sealed box design, ported
boxes can give more bass but it is less well defined:
A bass box in the boot firing at the boot lid will lose I guess 50% of the
half left through the boot lid (bad for convertibles!) - so you get
15% left of your original total ...
(100 - 50)/2 = 50/2 = 25%
....to bounce around and go out of the bottom, back and both sides of
the boot, the remaining 5th side being the back seat which now gets
5% of the energy you started with, to start making its way through
the back seat and bulkheads. If you lose only 1/3rd you'll end up with
3.3% of your power in the car.
By facing your driver into the car therefore you are already:
50%/3.3% = 15
times the sound power ahead. This is why I don't think you need to
worry about power - 250W rms into 4ohms will blow your windows
out - and matches the JBL power handling.
It will be as loud (to you, in the car) as a 3750Watt bass box in the
boot.
