What to do?
Matt_T
Post Fri Apr 21, 2006 8:29 pm
I really wouldnt want to be using 1inch spacers!
IMO your only realistic option is wider wheels, at least just wider rear ones? Cant you not get only a pair either wider or different offset?
M3 running gear would be a big task and not cheap!
Matt_T
Post Sat Apr 22, 2006 2:45 am
Yes, as in a 'pair' the same design as the fronts but wider you dummy :mad: Will save you from buying a full set and you keep the same design you like
