OIL BURN??
AndersLS
0.5l/10000 km...is this normal for a 325i/250k? my old 320i doesn´t burn any!!
pete320i
hi, dont no if that is normal, but my 320i does not burn any. sorry could not help.
320i dolphin grey.
- Homo Hair
i'd say that was ok yeah.. new renaults are quoted (by the manufacturer/dealer) @1l per 5k or something ridiculous like that bein normal
seems fine to me
some E46 330i's use a litre every 1000miles!
fuzzy
a litre every 1000 miles? suddenly my cossie doesnt look so bad
i've read and heard this from owners. BMW says it within their techincal spec
I mean M20's have an oil breather pipe from the rocker to the bloody throttle body so they are going to use some oil just from that!
S14's however have a oil condenser tank which feeds the oil back into the sump!
wildeian
Handbook reads:
0.15 litre per 100km (250 miles per pint). Like fuel consumption, engine oil consumption depends on the way in which the car is driven and on operating conditions.@'
Morat
Mine used about a litre in 4000 miles. I've been told that burning some oil is the price you pay for the longevity of these engines. If thats the case then I'm all for it.
bottlecapE30
my 2.7 would burn like mad then i changed to fram filter and cleaned all the intake and it doesn't burn a drop
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
mrLEE30
newer engines are designed to burn oil, mainly due to the bore coating and thats why they run with so much power and fuel economy, the gap between piston (ring) and bore is bigger allowing oil to lubricate it more thus less friction thus more power/better economy and this is why they burn oil. new Porsches burn silly amounts
older M20 engines are not designed this way, but burning oil is normal, excessive oil is not normal, but what counts as excessive is where people will disagree. both my E30's (320 and 325) use about a litre or so every couple thousand km, but there are bound to be a few leaks here and there so oil will be lost not as burnt but on your garage floor.
best bet is if there is excessive white smoke form the exhaust then its burning too much!
mrlee
mrlee
white smoke is water! headgasket.
blue is too much fuel and black oil!
M20's leak oil out of every hole they can! My old sport lump used very little between oil changes. use to be about a litre for every 4,000 miles roughly.
mrLEE30
white smoke is definately oil!!! if you have ever seen a turbo go you will get the idea, oil into to inlet = lots of white smoke!!! white steamy smoke is water and can also be caused by condensation in the exhaust when climatic conditions are right (i.e a high reliative humidity), and as you said headgasket
black smoke and blue smoke are normally fuel issues, but again excessive a small amount under hard acceleration is normal on an older engine.
mrlee
mrlee
wildeian
I've gotta agree with MrLee there
My old M20 was burning oil excessively and it kicked out white smoke (sh!t loads if I stopped at traffic lights!)
But I also agree that blue smoke can be burning oil too, but not on a Beemer!!
Dan318-is
my Is recently burnt 4/5 of a litre in 3000 miles!
Lordschleife
That sounds pretty similar to mine Dan, think I burned a litre or so in 4000miles maybe a bit less
However I do like to redline it once its warmed up
Cheers,
Robin
Robin
Globulator
Burning a small amount of oil creates a smoke of small particles - which will therefore look blue.
Burning a large amount of oil creates a smoke of big particles - which will therefore look white.
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
