OBC codes
Post Tue Apr 18, 2006 10:31 pm
i've never seen anyone ask about how to get the most from the 13 button obc, i can't even set the time and bloody date on the poxy things!
i've got m/g set right for economy and thats it :?
who knows there codes?! :D
gcorky
Boost Junkie
Post Tue Apr 18, 2006 10:35 pm
what codes?
525 sport
billgatese30
Post Tue Apr 18, 2006 10:38 pm
to set the time
press the time button so that the current time is displayed
then press the little button on the lower right hand side with a ball point pen
this will make the decimal point on the display dissapear
then adjust the time using the 1, 10, 100, 1000 buttons along the bottom (each button cycles the corresponding digit, i.e. button 1 does first number, button 10 does second number etc)
then when done press the little button with a pen again and the decimal point will return
to set the date do the same as above but obviously with the date on the display
don't use it for much else other than the m/g and temp my self so not sure about the other stuff
Simon
Post Tue Apr 18, 2006 11:09 pm
