saw this on another web site dont know if its been on here before some of you will see the funny side to this described as the e30 alternative tool kit
Alligator clips to permanently connect your SI board batteries to the useless front seat heating element wiring harness
Small coin with a hole drilled in the middle to replace your ICV.
Black duct tape to cover your Brake Lining warning light
Time release dry ice packets to reduce engine compartment heat
Drano for unplugging those pesky sunroof drains
Scratch and sniff imitation leather scent for leatherette interiors
Krylon bar-be-que paint for emergencies when you spot any chrome or bare metal parts on your car
Guppie Food to feed the fish that have taken up residence in your wheel wells
Vial of Norwegian cod liver oil to treat an onset of the Caradian Effect
Double stick tape to serve as drinkholders
Ice pick to be used to access or exit the vehicle in the event of a failure of either the self-locking system or the window switches
National GeographicԚ's Ԛ“Sounds of NatureԚâ€a CD to diagnose whether the groans and grunts you hear are because your guibo is failing or you just ran over a moose
Heating pads to treat whiplash when your Throttle Position Switch fails
Ԛ“Call GusԚâ€a emergency road signs
Mobile Traditions parts CD Ԛ—a one side with all original parts codes, the other side a recording of U2Ôš's Ԛ“Still HavenÔš't Found What IÔš'm LookinÔš' ForԚâ€a
bmw alternative tool kit
gazza
ad318i
LOVE IT...
Well found
Well found
1989 Alpine White 318i 4 Door - Got Scrapped When I Was Abroad
1993 Metallic Green 316i Touring - Im Selling it before i move back to Greece, http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0239342139
billgatese30
fecking brilliantgazza wrote:National Geographic’s “Sounds of Nature” CD to diagnose whether the groans and grunts you hear are because your guibo is failing or you just ran over a moose
Mobile Traditions parts CD – one side with all original parts codes, the other side a recording of U2’s “Still Haven’t Found What I’m Lookin’ For”
