Can of worms? rust in footwells!
oguz327
Captain Armco
Captain Armco
Thu Feb 16, 2006 4:58 pm
Well finally got my carpet out of my tech 1 after stripping the interior out to investigate leeks/wet carpet.
Good new is after romoving rear quarter card i can see that both rear inerer arches have been replaced probaly not long before i brought the car in 2003.
Bad new is some real bad rust around where the accelerator pedal meets the pedal floor mount :eek:
Passenger side was not too bad but may still need a bit of attention.
Any opinions or advise welcome
Kos
Thu Feb 16, 2006 5:13 pm
i have seen a lot worse!!!
www.pukardesigns.com
IG Pukar.Designs
jonb
Thu Feb 16, 2006 5:15 pm
kos
you should know plenty about rust. :)
oz. looks like someones had a go at "rebuilding" that drivers jacking point already.
oguz327
Captain Armco
Captain Armco
Thu Feb 16, 2006 5:33 pm
Are we talking big money to put right then guys?
I asume those corners are gonna be difficult to weld :?
dazleeds
old skool raver
old skool raver
Thu Feb 16, 2006 5:34 pm
very interested in whats said here lol
as i'll be doing the same next week
hope i dnt find too much rust :roll:
www.oldskoolfantasy.co.uk
Kos
Thu Feb 16, 2006 5:37 pm
jonb wrote:kos
yes i though it was a worth while mod to the M3 if that what you are on about. it cost me nothing to do and saved a few kg's, didnt see the point in spending Ԛ£1000 in carbon :wink:
IG Pukar.Designs
bullitt
Thu Feb 16, 2006 7:25 pm
oguz3001 wrote:Well finally got my carpet out of my tech 1 after stripping the interior out to investigate leeks/wet carpet.
1st things 1st Leak Test??
Use a garden hose or watering can to imitate rain fall a search for leaks, scuttle panel, bulkhead, screen seal, door seals & door membrain..
Try to make holes in the rust with a screwdriver..
If no holes appear and the metal is strong grind out a much as possible and treat it with a Rust Inhibitor then prime with an anti rust primer..
Holes!! The only way to tackle rust is to cut it out, i have replaced both these places on a mates sport by cutting out the section then fabricating and welding in new metal..
If you have a compressor, airsaw, mig welder & some common sense go 4it..:D
oguz327
Captain Armco
Captain Armco
Thu Feb 16, 2006 8:09 pm
Cheer bullit, ill try that for the leaks.
I think some of it will grind out and can be rust treated, but the bit by the accelerator pedal deffo has a small hole.
Deffo a 3rd party job just dont have the kit for this kind of work
oguz327
Captain Armco
Captain Armco
Thu Feb 16, 2006 9:47 pm
Has anyone had this type of problem and got it welded up?
Just wondering roughly how much this is gonna cost to put right :?
