Who has this? Is it a big improvement?
Are there any other Brake kits for our E30's?
Who has the Wilwood 4 pot kit?
M5pilot
Turbo-Brown
- Boost Junkie
I've got it, not used it in anger though.
It does need a bigger M/C as the pedal, whilst having a decent bit of firmness at the bottom, is a bit wooley otherwise
You also need to make up some plumbing fittings which make it more of a pain still!
bootyman
Hi Spec and Brembo also make some for the E30 i think
jmc330i
Tarox do a 6pot 285x22mm kit that fits under 15s.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
DieselMeister
Nice. I'd expect that this would be sufficeint for a stock sport and probably even an S50 powered one with nice pads / fluid / hoses etc.jmc330i wrote:Tarox do a 6pot 285x22mm kit that fits under 15s.
Decent suspension would be a must as I don't think E30s come with anti- dive / squat geometry like later threes
bootyman
Yeah and that Tarox setup will set you back about Ԛ£1150
M5pilot
Wilwood is only 400 but without pads. Why is Tarox so much more??
bootyman
You can have the one in the Wilwood in the For Sale section for only Ԛ£700 Sal
jmc330i
I did forget to write that bitbootyman wrote:Yeah and that Tarox setup will set you back about Ԛ£1150
James
'91 325i Sport
'91 325i Sport
