Sunroof Drain Hole Locations
clarko74
Post Sun Apr 07, 2024 9:09 am
My e30 is filling up with water and I suspect the sunroof drains are blocked. The footwells have been repaired and I am wondering if the sealer that was applied has blocked the holes. Does anyone have a photo showing the exact location of where the drains discharge at sill level or can explain in detail where they are so I can check? I would usually check the other side of the car for this sort of thing but as both sides have been repaired this isn't an option.
clarko74
