E34 sump help
Corasdad
Post Fri Feb 16, 2024 4:58 pm
Is there a part number for the front sump, I have seen a sump on eBay 1995 e34 but not sure if it fits m52
flybynite
Post Fri Feb 16, 2024 7:57 pm
Have a look on Realoem here
https://www.realoem.com/bmw/enUS/showpa ... Id=11_1898
Corasdad
Post Fri Feb 16, 2024 8:39 pm
Thanks its not the same, can't find one for less than 450, on the plus side I got 2 sets of engine arms for less than the price of 1 set
flybynite
Post Sat Feb 17, 2024 9:43 am
Unfortunately as these things have got rarer and no real alternative prices for some bits took a real hike through covid lockdown. Price has softened for many things bit not for everything. If you can wait, sometimes they do turn up but most know what they are in demand.
If you think E30 prices are high just try Escort E9 or 911 parts 8O
Corasdad
Post Sat Feb 17, 2024 10:21 am
Lol thanks will just have to bite the bullet I think.
I have just seen for sale a modified front subframe that means you can use rear facing sump, has anybody any experience with these
Post Sun Feb 18, 2024 1:58 pm
Cheapest one on ebay with the needed dipstick/pickup
https://www.ebay.co.uk/itm/404207505176 ... ondition=4
Corasdad
Post Sun Feb 18, 2024 2:11 pm
So reading that advert I need a different oil pick up as I think mine is m52tub28
Is this correct
https://www.ebay.co.uk/itm/134643149759 ... media=COPY
flybynite
Post Sun Feb 18, 2024 2:26 pm
Is this correct
No that is an M30 big six sump. you need one from the M50
Corasdad
Post Sun Feb 18, 2024 2:31 pm
I see thanks, do I still need oil pick up from e38
flybynite
Post Sun Feb 18, 2024 2:47 pm
Not sure what pickup the M52TU has but you can see what the M54 takes in the thread below. They are a similar engine and may have a similar oil pump, not sure. When you have the sump off the M52TU compare the oil pump to the M54 here
viewtopic.php?f=116&t=278433
Post Sun Feb 18, 2024 5:40 pm
For a TU or M54 engine you need the pickup from an E38 728i M52B28TU
Corasdad
Post Sun Feb 18, 2024 6:52 pm
Thanks dan
