E46 boot size
Corasdad
Post Fri Mar 03, 2023 8:57 pm
Does anybody have an e46 that would be willing to measure the width of the boot
flybynite
Post Fri Mar 03, 2023 9:15 pm
Corasdad wrote: ↑
Yes which bit do you want measuring? size of the opening or size of the outside of the boot? I have a facelift mooredoor if that helps
I can do it in the morning :thumb:
fixedwheelnut
Post Fri Mar 03, 2023 10:15 pm
Corasdad
Post Sat Mar 04, 2023 1:10 pm
I need the boot lid measuring where the spoiler would be fitted to the top surface please
Corasdad
Post Sat Mar 04, 2023 1:11 pm
Post Sat Mar 04, 2023 1:16 pm
Corasdad wrote: ↑
Saloon, coupe or cab ?
flybynite
Post Sat Mar 04, 2023 2:05 pm
Corasdad wrote: ↑
So my E46 is a 330i Sport with the factory lip spoiler. I think the 2-door should be the same, not sure about the cab.
Around the curve at the back the boot is 1160mm wide, 'across the flat' just in front of the spoiler is also 1160mm. The factory lip spoiler is 1155mm across the flat (fraction narrower than the boot) at the widest point.
The boot tapers towards the back so difficult to get an actual measurement as it all gets wider going forwards. I would say narrowest point it is 1150mm across the flat
HTH
I can measure again if you need something specific. :thumb:
Corasdad
Post Sat Mar 04, 2023 3:10 pm
