Hi guys,
Need your support.
I have a 318i 1985 (swaped with m42b18 E30 318is).
Since the purschase the rpm cluster never worked.
I changed the rev clock only with another One with econometer, changed the battery and km system kit but the issue remains.
As the 318i with m10 is electrónic I believe this is not an issue with connections but fell free to support.
Thanks in advance
318i - 318is cluster rpm issue
twright
Sometimes the tach doesn't work because the SI board batteries are dead. Check them with a voltmeter.
tpereir
The cluster was tested and all fine.
New battery in but issue remains.
Regarding the cables between cluster and Ecu how and were I can check?
Thanks in advance
Thanks in advance
fixedwheelnut
Have you checked the diagrams on the wiki? read this bit about the C101 plug
https://www.e30zone.net/e30wiki/index.p ... Tachometer
Instrument cluster wiring diagram here
[url]chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://www.e30zone.net/e30wiki/images/ ... e30_84.pdf[/url]
