ATF Lines
agistchau
Working on a manual swap, and getting around to removing the ATF lines. 90 degree bends make them a bitch to pull out, and I can't even get to one of them with a wrench to disconnect. Any reason not to just cut the line? I can't imagine auto trans parts are desirable, I don't see being able to offload many of these parts once the swap is done. https://9apps.ooo/
rix313
If you don't need them then yeah, have at it, chop the bastards off if it helps
