E30 e36 rack/e36 5lug HELP!
Prphte30
Post Fri Nov 12, 2021 4:04 am
Yo!!! So I have a 84 318 swapped with m50. I swapped the front suspension with e36 everything and e30 strut mounts and have a e36 rack. I am running e36 inner and outer tie rods and running power steering delete block and steering shaft kit from condor speed shop. My steering is extremely stiff. To the point I think somethings wrong. Is there anyone out there with a similar setup with the same issue? Need help ASAP! Thank you!!!
Post Fri Nov 12, 2021 9:16 pm
Take the silly blank off the ports and see if it changes
