You may know of this but you may not .
If your electric windows are stuck in the down position what do you do ?
Panic ??
On mine I think they were fitted by a dealer later on as the place where the winder handle was is just a plastic disc, so remove this and the small plastic plug over the top of a small shaft and .....................a 4mm allen bolt hole is there !!!!!!!
Allen key out and the window is back up again.
But you knew that , didn`t you ??
Electric windows down and out !!
Yes, I knew that as I have a similar set up. On mine Allen key is part of the tool kit. I have never used it so I don’t know if it works.
Blanca
Mine has the plug in the door card and the allen key in the tool kit but OEM fitted from new not dealer.
All comments by me should be taken in the right sprite, Jack Daniels is fine.
