caliper stripping/cleaning
dazleeds
old skool raver
old skool raver
Post Wed Feb 08, 2006 9:55 am
ok am stripping the rear discs etc off my breaker to go on my car
thinking to maybe get the calipers serviced while there off
whats the best way to get em mint??
sandblasting?? if so wherecan i get em done
also what should it cost to overhaul them properly
will be doing the fronts too
cheers
Daz
www.oldskoolfantasy.co.uk
Cava
Post Wed Feb 08, 2006 12:53 pm
Might be worth looking in to the cost of new calipers from somewhere like euro car parts. I think the rear calipers are not that expensive and you get a surcharge refund if you give your old calipers in exchange. This may work out just as cheap as getting the old ones reconditioned.
dazleeds
old skool raver
old skool raver
Post Wed Feb 08, 2006 1:03 pm
hmmm didnt think of that :D
are the ecp/gsf ones still genuine??
and not some substandard copies??
will have to look into this i think :P
Cava
Post Wed Feb 08, 2006 1:15 pm
The ecp ones I got for the front of my car were identical to the originals - I think they must get them from the original suppliers (they were german!). :D
Simon
Post Wed Feb 08, 2006 1:20 pm
Are the ones from GSF/ECP new? Or are they just refurbished, with new seals etc?
Cava
Post Wed Feb 08, 2006 1:34 pm
To be honest, I assumed they were reconditioned when i bought them, but they look absolutely mint (repainted, new seals etc), so if they are, they do a better job at sorting out old ones than I could ever do!
dazleeds
old skool raver
old skool raver
Post Wed Feb 08, 2006 1:35 pm
how much were they mate??
Cava
Post Wed Feb 08, 2006 1:41 pm
I needed the ate type for the front (which are a bit more expensive - typical!) which worked out to be about Ԛ£60 each. I think the girling type fronts were about Ԛ£40 and the rears are about Ԛ£50.
Jon_Bmw
Dangerous when thinking
Post Wed Feb 08, 2006 8:49 pm
Simon wrote:Are the ones from GSF/ECP new? Or are they just refurbished, with new seals etc?
I don't know for sure...
but as logic goes you are handing them back your old ones...so they arn't going to through them away as they have effectively given you money for them...so i'm almost certain any surcharge products such as calipers, steering racks etc etc are re-conned.
Nothing wrong with re-con stuff usually.
Simon
Post Wed Feb 08, 2006 8:58 pm
Yes, this is why I suspected they were reconditioned, not that I'm saying there's anything wrong with this though...
I'm just thinking you can DIY refurb yourself for less, I doubt you'd get the same finish though, you'd have to get them blasted.
I've only ever done one set, and they were quite easy to do.
dazleeds
old skool raver
old skool raver
Post Wed Feb 08, 2006 9:59 pm
yeah im thinking same si
no point spending 100plus
may as well get mine blasted and painted
shouldnt cost much more i doubt
and i get the finish of my choice then
right who knows a sandblaster in leeds /surrounding??? :cool:
Cava
Post Wed Feb 08, 2006 10:00 pm
Changing the seals did'nt bother me to much but there was no way I could get the caliper body to the same condition as the replacement unit - plus if anything is wrong with them, you can take them back!
jaistanley
Post Thu Feb 09, 2006 1:16 pm
I recently refurbed a set of M3 front calipers and plan to do it to all the M Roadster calipers I'm going to use.
First I attacked the bulk of the calipers with a grinder and flap disks. This got off all the scale and junk.
Then I blasted them with a spot blaster in a storage box with some clear plastic bag stretched over (not fun and slow but it worked).
The re-painted them with 2 pac high temperature paint.
Fitted new seals and slider kits from BMW.
Simple. The finish is excellent.
To finish the job I bought some new disks and panited the non braking surfaces (not where the face meets the hub or the wheels though)
It's not hard to do the same. You could also buy a re-hone tool for brake cylinders if you really want to go to town but I didn't see the need. The bores on mine were fine.
Jai
Cava
Post Thu Feb 09, 2006 2:25 pm
I should add that the reason I changed the calipers was due to a mechanical problem (rather than a cosmetic revamp). After 16 years good service, they decided to cook a set of new discs. After checking them over, the caliper body and piston were pretty bad, so I took the safe option and changed them. Can't really complain after using them for so long. :)
dazleeds
old skool raver
old skool raver
Post Thu Feb 09, 2006 2:32 pm
its purely a cosmetic thing
calipers are working fine
but may do seals anyway
cheers
E30cabrioman
Post Thu Feb 09, 2006 10:25 pm
Rear caliper seals are about Ԛ£8 from stealers....
Try any local engineering factorys near you for a sandblasting cage, then just ask if they will blast them for you ,just negotiate a price with them ,shudn't be to expensive
then paint and fit new seals
job done winkeye
325i Cab
E39 V8
Post Fri Feb 10, 2006 9:19 pm
Kit car fraternity use electricity, sodium carbonate solution and an iron electrode for cleaning off this kind of thing.
