Overhead check panel reset
anthperry
Post Sun Jul 18, 2021 7:52 am
Any tips on resetting the overhead check panel? Car is recently serviced and all items work fine however all lights remain on. I suspect a recent re-spray has caused some loose connections?!
Thoughts and help most welcome
Anth
onthames
Post Sun Jul 18, 2021 1:40 pm
anthperry wrote: ↑
Anth
Well pull the panel off and check the connection first
If doesn't fix try this: https://bimmertips.com/how-to-reset-bmw ... ion-light/
paultv
Post Mon Jul 19, 2021 6:53 pm
Simple generic reset...disconnect the battery for 10 seconds...if all still on then you have a real fault.
Paul :-)
