Hi, what are the differences with the manual and auto ecu for 325i engine?
If I were to convert mine to manual, why would I need a different ecu??
Difference manual auto ecu
Acaciastrain360
1989 Auto 325i cirrusblau metallic more door
1989 316i Atlantisblau more door
1987 Auto 525e ETA Saturnblau
AFAIK, the only 325i Auto that had a 'different' ECU was the 1987 version, which had a 164 ECU as per this list:
https://www.e30zone.net/e30wiki/index.php?title=ECU
The later ones like yours, as far as I am aware, just used the same 173/380 ECU.
Presumably, the idle speed increases a bit when the automatic gearbox is put into drive, rather like when you rev the engine a bit when moving away from a standstill in a manual car...
Acaciastrain360
Hey thanks for your reply, from what I see on that list, it is listed as having a different ecu? 164? I mean, the best I can do is convert to manual and just see if it works hahaSpeedtouch wrote: ↑Mon Jun 21, 2021 10:36 amAFAIK, the only 325i Auto that had a 'different' ECU was the 1987 version, which had a 164 ECU as per this list:
Acaciastrain360
That's why I mentioned it; according to the list, the later cars just had either the 173 or 380 ECU, hence should be compatible with either manual or automatic.
In any case, a simple enough swap with the 164 ECU if need be...
Acaciastrain360
Sweet thanks dude
JungleGus
AFAIK if you're converting Auto > Manual you don't need to change ECU.
