BRAKE CALIPERS
yaad
Post Wed May 19, 2021 10:02 am
Hi guys
i have just changed my brake pads but my calipers, caliper bracket and the brake disc guard are all rusty. does anybody know the best way to clean these up so they look new? DIY job or for a professional?
thanks
yaad
Blanca
Post Wed May 19, 2021 10:38 am
Just use a quality rust remover like Carlston, wash off, dry and paint. But take care, rust remover is very toxic.
I am lucky, no rust here.
All comments by me should be taken in the right sprite, Jack Daniels is fine.
paultv
Post Thu May 20, 2021 8:48 am
and be sure to use brake caliper enamel - its heat and salt and everything resistant and you can use crazy colors too!
Paul :-)
flybynite
Post Thu May 20, 2021 8:55 am
Depends what you want, if you want them to look good then good clean, wire brush, rust converter, than caliper paint as above. Easy to do at home.
If you want them like new then it is electrolysis rust removal, media blasting and then electroplating with zinc passivate. Possible to do at home but best left to a professional
