Which battery?
Cloggy Saint
Post Tue Apr 20, 2021 5:52 pm
Yet again I have to replace the battery in my touring. The last 2 I've bought have been Bosch S5008 which have lasted no more than a couple of years (combination of very little use and crap smart chargers). My local motor factor recommends Yuasa but they have very poor ratings on trustpilot, what are people's recommendations?
Post Tue Apr 20, 2021 7:20 pm
Varta E11 is what id recommend, 4 year warranty
Bosch batteries are rubbish
Cloggy Saint
Post Wed Apr 21, 2021 12:38 am
Cheers Dan, they're a decent price on ebay. I guess I can ignore the 'this part doesn't fit your car' stuff?
flybynite
Post Wed Apr 21, 2021 8:41 am
DanThe wrote: ↑
I always tend to use Varta because they are generally cheaper than the Bosch, but they are made in the same factory by the same people and have been since they were bought by Johnson (now Brookfield) in 2002.
Cloggy Saint wrote: ↑
I would guess that whatever you are doing that is knackering the Bosch will knacker the Varta the same, but I would still use the Varta as I don’t think there is a better battery. Things just ain’t made like they used to be.
If you know you are going to knacker it, might be worth just getting the cheapest (have you tried Tayna?)
What charger are you using? The Cteks I use seem to work well but standing is hard on any battery
ocde30
Post Wed Apr 21, 2021 9:19 am
Fitted a Varta D24 to my 318 a few months ago and I'm very happy with it - I know only time and lack of use will tell. Online service and price from Battery Megastore was excellent.
Post Wed Apr 21, 2021 5:05 pm
I have two for the Baur, a Bosch and a "Pro-Bat" the later being over five years old and both are still going strong but I do disconnect when I know it wont be used for a while.
The Pro-Bat has sat in the boot for nearly a year now and is still strong and will start the car .
twenty
Post Wed Apr 21, 2021 6:38 pm
Forget Varta, Bosch etc. Have you tried BMW?
The BMW ones are the real deal. Best thing is that they don't cost a lot more but much better quality and longivity.
If you do decide to go for non BMW, then best option is Exide premium - cheaper than Bosch, Varta etc. but just as good if not better.
reggid
Post Thu Apr 22, 2021 3:57 am
get one from dealer, last two (2) Exide OE ive had have gone basically 10 years
E30 325is with M20B31
Post Thu Apr 22, 2021 7:52 am
There are a couple of reasons I wouldn't buy from the dealer,
They like to bend you over the counter
The warranty is not worth the paper it is written on
Post Thu Apr 22, 2021 11:23 am
Over the past 20 years so of my personal experience, I have found that batteries from BMW main dealers did not last very long. The best battery for long life I have found Varta to be unbeatable with Bosch a little worse. In my three cars I have found they last an average of at least 10 years and in one case about 15 years!
Satan
Post Thu Apr 22, 2021 12:05 pm
Is the battery still under warranty?
Cloggy Saint
Post Thu Apr 22, 2021 12:45 pm
Satan wrote: ↑
Not sure, probably as I've only had it 2 years but I can't really blame the battery as it's demise is mainly down to lack of use. A new Varta arrived today so I'll hook it up and get a decent smart charger and see how it goes.
paultv
Post Thu Apr 22, 2021 2:20 pm
Useful explanation about lead acid batteries:
https://www.victronenergy.com/live/drafts:battery_life
Paul ;-)
Cloggy Saint
Post Tue May 25, 2021 2:01 pm
Ok, so I bought and fitted the Varta and buggered my back in the process. Five weeks later I can walk again, go to start the car and the battery is completely flat. Is it normal for a new battery to die without use within this time or do i have a drain? I did check for a drain when the previous battery kept dying but nothing registered.
paultv
Post Tue May 25, 2021 4:35 pm
Check daft things like boot lights and glove box - make sure they are off - or pull the bulbs to see if any affect the discharge - sure should register but maybe intermittent.
Just a thought,
Paul :-)
Cloggy Saint
Post Tue May 25, 2021 5:51 pm
I've already been over it with a fine toothed comb and there's nothing obvious going on :? . Worryingly, I've got 3 chargers and none of them are doing the job. Either all 3 are knackered (unlikely) or the battery is already beyond help, which seems equally unlikely considering it's new.
