Can somebody identify what these wires are for?
BobIzYaUncle
Post Sun Dec 13, 2020 11:45 pm
My latest post on my build thread shows my engine harness I've just cleaned and reerapped. Does anybody know what these are for? The were unpluged but are able to be connected. There's also 1 at the other end of harness but only 1 plug and nowhere to connect it.
1991 318i convertable
Thanks in advance
Post Mon Dec 14, 2020 11:00 am
It would help if you gave some idea of where in the car we are looking, what colour the wires are, but I'll assume it's the engine loom and the wires are grey/black.
If so, and your car does not have a cat. and lambda sensor, then they should be connected. There is a potentiometer, under a red cap, on your air flow meter, which is used to set the idle CO level. This wire carries the adjustable voltage from this pot. to the engine ECU.
If you do have a cat. and lambda sensor, the wires should not be connected, since the signal from the lambda sensor is used to control CO.
BobIzYaUncle
Post Mon Dec 14, 2020 12:51 pm
Brianmoooore wrote: ↑
Hi mate, sorry for lack of info, I dint realise it would be relevant and I thought I had stated engine harness. My mistake
It's on the engine harness across the bulkhead under the long plastic trim. It has a catalyst and lambda sensor but no adjustment screw on the air flow metre.
Wire colour is black and white (arguably grey)
Cheers for the info πŸ‘
Post Mon Dec 14, 2020 1:30 pm
That's definitely the connector for the CO pot, and on your car should be left disconnected.
Some late M40 engined E30s, after lambda sensors and emissions equipment became standard, were fitted with AFMs that omitted the pot. for cost reasons.
BobIzYaUncle
Post Tue Dec 15, 2020 12:09 am
Thanks a million.
